Question about Samsung HP-R4252 42 in. Plasma HDTV
Screen was going red on the top half of the screen, then..
Screen was going red on the top half of the TV - intermittently, then the bottom half went black while the top half was still visible, now the entire screen is completely black. Sound is clear - just no picture. Which components need to be replaced? Can they be ordered? and what boards are they?
  • 585 Answers
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
Posted on Aug 01, 2009
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Tv was dropped. Bottom half works, top doesn't
Hi friend,,,
welcome to fixya
Commonly for LCD tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
52" Samsung that the top half of screen goes black.
the HDTV has a heat-related problem check your fans. Do they remove heat? the vertical chips paint the screen from top to middle and, middle to bottom so; your top to middle vertical chip is overheating as is your video chip; that is why you have "glitter" in the back ground. get rid of the heat or, bye,bye TV.
May 20, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Total black TV
hey hello, you have a bad buffer board. some tvs have them on the sides and another tvs have top and bottom of the screen.it should not cost more than $150.00 for the board. i think that's too much.a tech will determine easy and fast the one that is bad. that is a fast repair good luck
caypianan@yahoo.com
May 10, 2009 | Sanyo DP42746 42 in. Plasma Television
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Color distortion for Sony KPR-46cx35
there maybe cold solder around the chroma section, or in the CRT board....
Aug 11, 2008 | Televison & Video
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Samsung HP-R4252 42 in. Plasma HDTV Logo
466 people viewed this question
Jerry Greenberg
Jerry Greenberg
