Question about Epson Stylus C88 InkJet Photo Printer
GREEN LIGHT KEEPS FLASHING ON M
On my STYLUS c88+ THE GREEN LIGHT KEEP FLASHING AND MY PRINTER KEEPS PRINTING aLL ???????????????????? ON THE PAPER What can i do to fix this problem.
  • 164 Answers
Www.aa1consulting.com
sounds like it may be a driver problem or perhaps the spooler service needs to be stopped and restarted
Posted on Jul 24, 2009
2 Suggested Answers
aicaxz
  • 511 Answers
SOURCE: GREEN LIGHT KEEPS FLASHING ON MY PRINTER
Green light flashing means printer is in printing process. No problem. If you want to stop printing. delete printing job from printer properties or stop printing from status monitor.
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Paper just keeps feeding through no printing & green light just keeps flashing. How do I know when paper is loaded correctly
It could be a problem with holder shaft & Rollers. Turn off the printer and clean the rollers with lint free cloth.
make sure you shuffle the paper before placing them in the tray and stack the paper tray properly for any loose connections.
Regards,
Ron
Mar 07, 2011 | Epson Stylus Photo R300 InkJet Printer
Epson C88 shows red alternately blinking lights
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Feb 05, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson C88 will not print, is flashing both paper and ink lights
I think you need to reset the counter, you can either take it into a epson service centre & have them reset it, or download a programme online.
you just need to google it, just type in service reset C88 that should do the trick.
Nov 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 plus
Make sure that the head can move on the carriage bar as this indicates a head assembly lock or jam. Make sure all the paper paths are clear and there is no tiny piece of paper stuck. Power it back on. If this does not resolve then you will need a visit to the repair shop or buy a new printer which is probably cheaper!
Sep 11, 2009 | Epson Stylus C88 InkJet Photo Printer
Stopped printing both ink and paper red light
Depending on the way the lights are flashing you could be able to fix this reasonably easily.
If the lights are flashing at high speed together (ie: at the same time) then it's a fatal error and the chances are you have some kind of problem such as:
  • paper jamming up the works
  • loose wiring
  • the cleaning station sometimes pops up out of position and stops the printhead getting back into the parked position. If this is the cause you have to push the white wiper plastic down and to the right before allowing it back up and into the mated position with the parking pad. Takes a little work but it's easy enough.
Problem #2 is the waste pads and that's indicated by the flashing lights alternating rather than together.
If it's this then rather than reinvent the wheel (I've posted about this soooo many times now) here's a helpful little guide here:
http://www.octoink.co.uk/store/pages/Epson-C86.html (the C86 is the same as the C88 in terms of the waste pump/tubing design)
Resetting the waste ink counter requires the SSC utility from ssclg.com or a suitable adjustment utility which can be found for download if you search hard...
Hope that lot helps but if you get stuck, post again and I'll do what I can.
Cheers,
Martin
Aug 03, 2009 | Epson Stylus C88 InkJet Photo Printer
Jul 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer will not print
Which of the two red lights is on? If it's the red paper light, it simply thinks it's out of paper. Make sure your stack of paper is properly seated in the Automatic Sheet Feeder. If it is the red ink light, it means that during a print task (printing, head cleaning, ink charging), an empty cartridge was detected. Go through the cartridge replacement procedure as described in your User Manual. If you don't have one, see:
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
"Replacing an Ink Cartridge.
If this information doesn't answer your question, please post a new comment with more information on what you want.
If this information was a help, please rate it.
Jan 25, 2009 | Epson Stylus C88 InkJet Photo Printer
Both Lights are flashing on Epson Stylus C88+ green light is out. What to do.
I had the same prob, but found out it was caused by the carriage not being able to move - if the inkbay door is ajar even a tad it causes an obstruction.
I'd open it up and look around for any paper jams or obstruction, clear out any pending print jobs, then turn it off for a while...I did this once and it's humming along now...hope this helps!
Dec 28, 2008 | Epson Stylus C88 InkJet Photo Printer
Both lights flashing on c88
Were you trying to feed a shirt through the printer?
LOL, press the center button.
Jul 26, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
