Car Audio & Video Logo
Jason Levan Posted on Mar 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a pyramid lock but I don't have the key, how do I get a key.
DROPNDEAL
Level 3:
Top Expert:
  • Pyramid Master 2,931 Answers
  • Posted on Feb 10, 2018
DROPNDEAL
Pyramid Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932523
Points
21770
Recommend contacting a local car audio professional or Pyramid customer support directly here
http://www.pyramidcaraudio.com/ContactUs.aspx
I have a pyramid lock but I don't have the key, ho - helpful-j2fqtt4x4km4a1x1cbly0mof-5-0_9.png
Why were pyramids built/what were they used for
hi Emmi.
The ancient Egyptians built pyramids as tombs for the pharaohs and their queens. The pharaohs were buried in pyramids of many different shapes and sizes from before the beginning of the Old Kingdom to the end of the Middle Kingdom. There are about eighty pyramids known today from ancient Egypt.
Pyramids - Ancient Egypt
www.ancientegypt.co.uk/pyramids/home.html
Why was the great pyramids built?The Great Pyramid of Giza was built for the Fourth Dynasty Pharaoh Khufu (or Cheops), and was completed around 2560 BCE. ... The Great Pyramid is the largest of the three pyramids, and it is part of its own smaller complex that also contain 3 smallpyramids that were built for Khufu's wives.The Great Pyramid of Giza: Last Remaining Wonder of the Ancient ...https://www.ancient.eu/article/124/the-great-pyramid-of-giza-last-remaining-wonder-of/
What was the purpose of the pyramid?Pyramids. The ancient Egyptians built pyramids as tombs for the pharaohs and their queens. The pharaohs were buried in pyramids of many different shapes and sizes from before the beginning of the Old Kingdom to the end of the Middle Kingdom. There are about eighty pyramids known today from ancient Egypt.Pyramids - Ancient Egyptwww.ancientegypt.co.uk/pyramids/home.htmlSearch for: What was the purpose of the pyramid?
How many years did it take to build the pyramids?20 yearsThe Great Pyramid, also known as the Pyramid of Cheops, in Giza, Egypt took 20 years to build.18 Feb 2010How long did it take to build the Great Pyramid in Egypt? - Travel Mamashttps://travelmamas.com/how-long-did-it-take-to-build-the-great-pyramid-in-egypt/Search for: How many years did it take to build the pyramids?
if you want to know more go to this link.
Why were pyramids built what were they used for Google Search
Expedition door lock
Replace the battery on the key fob! Also, it may need to be reprogrammed by the Dealer!
Dr. Gene n Landrum
I have lost the keys to my locked Pyramid Bike Lock bike which has been locked up for seven years. How do I open the lick up to take the bike in to be cleaned up and tires fixed, etc. please?
Take a 4 inch Grinder and grind the (ie)cable or chain into; Or a pair of bolt cutters and cut it into; You Can METABO IT into
Aug 29, 2011 • Cycling
1helpful
I have a pyramid amp and i don't know what watt it is and it doesn't say. the model no. is PB-700A. it's an older amp thank you
  • 4-Channel
  • 350W X 2 Max @ 4ohm
  • 700W X 1 Bridged @ 4ohm
  • Dim: 2.4"H X 10.7"W X 6.9"L
  • Mosfet Pwm Power Supply
8helpful
How tall is the average pyramid
The first Egyptian pyramid was 204 feet or 62 meters high, built at the direction on Pharoah Djoser in around 2630 B.C. The tallest was the Great Pyramid at Giza, standing at an impressive 481 feet or 147 meters. The smallest was the Pyramid of Pepi II, which stood at a paltry 172 feet or 52 meters. Just based on Egyptian pyramids, the average height is about 316.5 feet or 96.375 meters. Considering the technology of the day, the pyramid builders were quite impressive to say the least. Hope this helped and best wishes.
1helpful
Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
3answers
In car graphic equalizer installation
035132ed-916f-4d02-8e5e-9fa428212a36.jpgPyramid stereo graphic equalizer model 9700g - Page 6
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
