Question about GPS
Magellan roadmate 1430 no sat signal
Hello, i have a magellan roadmate 1430. After using it for 2 days it wont pick up a satellite signal anymore. Ive tried the reset but it doesnt help. Any ideas? Also, how do you do a hard boot on these? I cant really find anything on the net about it. Thanks
    Brigadier General:
  • 4,090 Answers
Replace the or recharge the battery to capacity and see if that helps usually low battery, incorrecty baud rate or port out cause no satellite connection, unless you are under a thick concrete or tin roof. take it outside and show it some sky and see if that help
Posted on Jul 26, 2009
Change my magellan roadmate from canada to usa
This model does not have map coverage of Canada. This model was designed for us only in the US. The models in that series with Canada maps were the RoadMate 1212, 1412, and 1430.
Oct 12, 2014 | Magellan Roadmate 1200 Car GPS Receiver
My Magellan Roadmate 3045 is not getting any signal. I turn it on, and it doesn't even attempt to acquire a signal. The satellite icon in the top right-hand corner of the menu which indicates signal...
Mine actually stopped working the same day you posted this. How strange is that? I have not been able to figure out what is wrong with it. Have you figured out a solution?
Aug 06, 2011 | Magellan Roadmate 3045 - uses Gomadic...
Road mate 700 won't pick up satellite signal
If this unit has an internal battery it may be bad, other wise I would reload the software or get a updated version of the operating software. Have you contacted Magellan?
Dec 03, 2010 | Magellan RoadMate 700 GPS Receiver
The power won't come back on
there is a fuse in the tip of the plug that goes into the socket. unscrew the end of the plug to gain access to the fuse.
Mar 31, 2010 | Magellan RoadMate 1430 GPS Receiver
Can you download an update for a magellan roadmate 1430?
Yes you can: Enter your info here http://www.magellangps.com/support/
English Manual: http://docs.google.com/viewer?url=http%3A%2F%2Fwww.magellangps.com%2Fassets%2Fmanuals%2Froadmate_1430_manual_en.pdf
Magellan® RoadMate® 1430 Software Update Version 3.12: http://www.magellangps.com/support/chooser.asp?prodid=2056&supportid=806
2009 Spring Map Update: http://www.magellangps.com/products/map.asp?tab=0&PRODID=2194
As for connecting it to the computer, you'll need the usb cable that came with it. Then you'll want to do this:
Follow these steps to connect your Magellan RoadMate to your PC.
  1. Turn ON your Magellan RoadMate.
  2. Touch "Map" to display the map screen.
  3. Connect your GPS to your PC using the USB cable.
Oct 19, 2009 | GPS
Magellan Roadmate 1200 won't lock onto any satellites. Satellite tracking is zero. Worked two days perfectly, day three, nothing. Brisco
check that your battery is fully charged use an AC charger if you have one.
Check Baud rate and port are set in accordance with manual
Jul 26, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Magellan roadmate 1430 calibration is wrong
try a hard reset again using a paper clip, insert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update (if you havent already) off the magellan site..you must register the unit with magellan before you can download the update.
Jul 02, 2009 | Magellan RoadMate 1430 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
GPS Logo
442 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
