SOURCE: Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
SOURCE: How to I fix a spin casting reel?
You should be able to remove the spool by removing the knob on the front of the reel which also is the drag adjustment. With the knob off the spool should pull right off. Hope this helps you
SOURCE: reels on reel to reel
sounds like a loose drive belt. replace it. or a bad tape try another brand.
SOURCE: where can i find reassembly instructions for a shakespeare easy cast 35 reel
The maintence section from the Shakespeare ez-cast reel owner's manual is below. I hope it helps!
You can find the complete owner's manual here: http://s7d5.scene7.com/is/content/purefishing/skp-ownerM-ezCast
