SOURCE: Humidifier doesn't work as it used to,,,,,
First check to see if the two water sensing probes have been cleaned. After cleaning, if the problem still persists, try the following.
There is a small thermostat switch that sits on the heating coil underneath. This thermostat is designed to prevent the coil from overheating when no water is present. What probably has happened is the switch is doing what is designed to do but has become defective and is opening and closing at a lower temperature. So what is happening is the red light reset indicator will come on because this switch opens, the coil starts to cool and the switch closes and the light goes off. Because it is defective, this is occurring when it shouldn’t, causing this maddening on/off cycle.
Fortunately, this sensor is easy to replace if you’re handy. Make sure you unplug the humidifier from power. Turn it over, remove six screws, and carefully lift the lid. Look toward the heating element and you will see a small button type device with two wires plugged into it and is attached with two screws off to the side of the element. This particular thermostat is obsolete and very difficult to find. However, there is an excellent substitute made by Stancor for around $5.00. Their part number is STO-325.
Remove the two screws and lift off the thermostat and slide the wire connectors off. Simply reverse the process for installation and be careful to replace the bottom lid, being careful not to crimp the wiring.
SOURCE: Left Tank won't empty
Eureka! Solved my "left bottle not emptying" problem. The problem was not with the bottle but that the top of unit which houses the on/off switch was not seated properly. It takes only a very slight difference in water level for the float to activate the switch, therefore if the top is raised even 1/4" the unit will shut off before the water level is low enough to allow the left bottle to drain.
SOURCE: Carrier SBP Humidifier is not working
I would suggest turning up the humidistat (usually located on the the return air duct to a higher setting and listening for a "click" noise on the supply valve. If you do hear a click but dont see / hear any water than the culprit is likely the valve itself.
SOURCE: My air-o-swiss 7142 humidifier keeps
The water sensor is a float in the mister area of the base. The float is off in one corner with a little plastic barrier around it and translucent cap over it. Make sure the float can more freely. If the float can move up and down but the light stays on, the reed switch (a switch controlled by a magnet built into the float) inside the unit might have been knocked loose, damaged or disconnected. The switch is actually inside the post that the float slides on, but it can only be accessed from the underside - inside the unit.
SOURCE: Water tank broken
Hi, I think you can purchase from amazon. take a look here: Maintain Your Home Environment From Anywhere. I hope this helped you. Have a nice day
