Admiral 36 white line across the middle of screen
Line across screen
    Genius:
  • 1,550 Answers
Change the vertical IC are damaged
Posted on Jul 24, 2009
Good picture but a squigly line
Will you please provide more details> Is the line across the screen at its middle?
Jan 02, 2013 | Sony FD Trinitron WEGA KD-36FS130 36" TV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
The dropped television
If it has a white line across the middle then it is probably repairable.
If the screen was cracked it could, but probably wouldn't work at all, not even a white line. The white line indicates that the vertical deflection IC has failed. Generally these IC are inexpensive and should only take an hour, if that, to replace. A good technitian should be able to repair it at a reasonable cost as well as check it over for other common problem areas.
Mar 11, 2008 | Toshiba CF36G40 36" TV
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
281 people viewed this question
Top Televison & Video Experts
Electro Med Services...
