Question about Microsoft Xbox 360 Controller
Wireless Control My sons new wireless controller worked for a week, now the light in the middle just keeps going round and it wont work. Per the response regarding the signal, we tried pressing the white button and it still isn't working. Any other suggestions?
  • 120 Answers
If this for xbox 360 elite or just regular, your wireless controller need a good battery, Once you replace the battery. Connect the wireless controller on your xbox closely and go the sub menu of xbox 360 to check the configuration for wireless.
Posted on Jul 23, 2009
When i try to play my wireless controller wont work the button in the middle just blinks green all around help
If you've tried properly syncing your controller and it still doesnt work you might need new ring of light board.
Dec 26, 2010 | Microsoft Xbox 360 Wireless Controller
I just have a new connection through twc and now
Hi Friend,
Please follow the steps in order to resolve the wireless issue:
1.Connect the router to a computer.
2.Type 192.168.1.1 in the web browser and hit enter
3.Enter the username and password(default password is admin and leve the username blank)
4.On the setup page click "Wireless" tab and fill the sections as mentioned
Wireless network Mode:Mixed
Wireless network Name-As per your choice
Wireless Channel-6-2.437GHz
Wireless RF Control-Standard
Wireless SSID Broadcast-Enable and click Save Settings.
5.Click Wireless Security and fill the sections as mentioned;
Security Mode-WEP
WEP Encryption 64 bits 10Hex digits
Key1-Enter 10 digit or 10 letter password(example-your telephone number) and click Save Settings
6.Click Advanced Wireless Settings and fill the sections:
Beacon Interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click Save settings.
Turn off the router for 30 seconds and turn it on again.
I hope this will resolve the issue.
Regards
Chiranjeet
May 28, 2010 | Linksys Wireless-G WRT54G Router
Gamestop Edge PS2 Wireless controller wont work. New batteries and the square control (router) box just keeps blinking green. I pressed the button for reconnect and it still does nothing I need...
If the light on the controller is flashing then the batteries are still good. There is a small reset button on the receiver that came with the controller. use a needle to reset it while it is still in the ps2. make sure that the ps2 is turned on and the green light is flashing on it. it should blink a few times and then the light on the controller should turn red. once it does then press start and your good to go.
Hope this helps!
Nov 08, 2009 | Gamestop Edge Wireless Controller for Xbox...
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
My sons new wireless controller worked 4a few days, now the light in the middle just keeps going round and it wont work.
The controller may have lost the signal from the xbox 360. You can try turning the unit on and then the controller. There should be a small white button on the front of the controller, if you press that it will search for the signal from the xbox 360. Hopefully this helps.
Jun 29, 2009 | Microsoft Xbox 360 Controller
Tried connecting controller with xbox on and buttons doesnt work
If you power up a new controller and the Ring of Light lights just keep cycling around in a circle without settling on a position, this means that the game console does not recognize that controller.
This can happen with a new controller or when replacing batteries.
To sync it up with the XBox 360, you need to first turn on your game machine,
then turn on the wireless controller (push the Xbox button and hold it until it lights up),
then press the little connect button on the game console (round button to the right of the two memory slots on the front of the machine),
then press the connect button on the rear of the wireless controller in between the left and right buttons that you normally push with your index fingers (above and to the right of the battery release button).
The Ring of Light will cycle on the controller and then it will be assigned a position by the Xbox and stay lit. To turn a controller off or disconnect it, press and hold the Xbox button in the middle for a second or two until the light goes off - if you are in the middle of a game it will ask you if you want to turn off just the controller or the console as well. When the console powers down, all wireless controllers are automatically turned off.
If this does not work, attempt to connect with a different controller to make sure that the controller you are trying to use is not defective.
Hope this helps!
Apr 06, 2009 | Microsoft Xbox 360 Wireless Controller
Wireless controller doesnt work, the light comes on when you hold button down but it keeps flashing, it is brand new & we cant find the receipt it never has worked
You have to synchronize the controller, press the small sync button on the Xbox, then press and hold the big round button in the middle of the controler.
Mar 08, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wireless control pad wont connect
have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
Feb 07, 2009 | Microsoft Xbox 360 Console
LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Jan 14, 2009 | LG LSC121PMA Split System Air Conditioner
Wireless xbox 360 control pad
Sorry if you have done this and I'm being really patronising but have you held down the connect button on both the controller and the console?
Jun 02, 2008 | Microsoft Xbox 360 Wireless Controller and...
Microsoft Xbox 360 Controller Logo
347 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
