Question about Sanyo DP32746 32 in. LCD Television
I turn on t.v. but 5 secounds the t.v. turns off
Sanyo 42 inch flat screen
  • Sanyo Master
  • 5,568 Answers
Loss of sound + loss of video = failed/failing main power supply.
Without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Jul 24, 2009
  • 120 Answers
Your TV has a protected circuit in order not to damage other circuit due to there is a bad or broken semiconductor maybe on power section circuit. bring your tv to expert electronics technician.
Posted on Jul 23, 2009
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
Sanyo 2008 flat screen 42 inch no picture have sound
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 26, 2012 | Sanyo 42K40 42 inch Multi-System LCD TV
Sanyo 42 inch tv model number dp47460 turns off after a half hour
Hello
Check its power regulator board's soldering points for any loose solderings. Resolder all the suspected solder points by applying a little more solder.
Mar 05, 2012 | Sanyo 42 in. LCD TV
I have a Sanyo 42 inch T.V. and it suddenly shut off. I tried turning it back on by using the remote. the green light comes on for a few seconds and shuts off again.the screen never powers up.
call to the tv service center and do the required things my dear..........
plz dont try to repair it without any experts becoz tv when switched off also contains many voltage in it...
Jan 22, 2011 | Sanyo 42 in. LCD TV
My 46 inch Sanyo flat screen turns on and right off again
Might be worth it if it cost over 500.00 dollars, I had a simular problem with a Yamaha HTR receiver... the cause was the power adapter/converter was overheating... so it sounds like something along those lines... It cost me 129.00 dollars to fix my receiver so I would say 100.00 dollars or less... I saw a 42" LCD at the local electronic's store selling New ones for about 400.00 now..
Mar 25, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Sanyo 50 inch plamsa just quit!
the power supply of the tv is too sensitive. you need to have a good spike guard for this.
Jan 10, 2009 | Sanyo DP42746 42 in. Plasma Television
Screen goes black but still have sound
MINE TOO AND SANYO TOOK THIS TV OFF ITS SUPPORT WE SHOULD ALL SUE THIS COMPANY gcolella@snet.net
Jul 26, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP32746 32 in. LCD Television Logo
211 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
