Question about Goodman Heating & Cooling
CONNECT AC TO AIR HANDLER
HOW DO I CONNECT A GOODMAN 2 WIRE AC TO A LUX 5 WIRE AIR HANDLER
  • 614 Answers
Wire tstat normaly> Take the Y off the tstat and it goes to the outside unit. The other wire from the outside init goes to the common off the transformer. This is marked with blue,brown or black. Russ
Posted on Jul 23, 2009
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
Im trying to wire a goodman 5 wire air handler to my 4 wire t-stat and 2 wire condenser can u help
remove the jumper from the t-stat between rh & rw then the stat will be 5 wire
Apr 02, 2011 | Goodman Heating & Cooling
I have a goodman ac unit in my apartment complex that is blowing 5 amp fuses in the air handler.
The low voltage wire to the out side is shorted somewhere or the contactor coil is burnt.Thats all it could be one or the other.
Jan 05, 2011 | Heating & Cooling
No heat, got great a/c....
W1 and W2 are the differences from the single stage to the two stage. Im thinking its your thermostat is not programed for 1 heat / 1 cool. You probably had 2 heat / 1 cool before.
Oct 17, 2009 | Goodman Heating & Cooling
I have a goodman gmnte with a 16 seer ac, just
yes in the air handler the blower will have possibly 4 wires the ones you are needing are red blue and black1 will go to a relay or possibly a circuit board and the other 2 will capped off, black is high speed, blue is medium, red is low, most come from factory on med.
Aug 11, 2009 | Heating & Cooling
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
Wiring diagam for goodman heatpump and air handler to thermostate
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Oct 09, 2008 | Goodman Heating & Cooling
Need line set size for goodman ck-36-1a
If your running gas heat it's 5/8 3/8 tubing.If it's elec. heat it's 3/4 3/8 tubing. Etheirway 3/4 3/8 works for both. Use 6 wire for tstat from tstat to furnace or air handler, and you need is 2 wire from condensing unit [outside] to furnace or air handler or anything more than two.
Sep 26, 2008 | Goodman Heating & Cooling
Goodman GSC130601BC A/C unit not working
AIR HANDLER
Sep 08, 2008 | Goodman Heating & Cooling
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
131 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
