I have a Haier 8000 BTU Air conditioner and it smells sooo bad.
When I turn our unit on, it smells soooooo bad, I can't breathe. Anyone have a solution? The unit is about 2-3 years old.
  • 3,600 Answers
You need to replace the air filter and shoot some fabreeze intothe ducts and clean the water pipe drian.
Posted on Jul 23, 2009
Is water supposed to leak out of the back
no only out of the drain check to see if it is clogged or does not have a p trap in it it should
Sep 14, 2014 | Haier CPRB08XCJ 8000 BTU Portable Air...
Water is leaking in front
Tip the air condition back so water drains outside window.
Jul 14, 2013 | Haier Esa408k-l Window Air Conditioner...
Model # hwr08xc7 8000 btu. The air conditioner turns on but all it does is blow warm air no matter what setting i have it on.
you can take off the front cover and under the control panel, on newer units have a relay that the low voltage thermostat controls and by pass it. WARNING IT WILL NOT CYCLE NOW AND WILL NEED TO BE UN PLUGGED WHEN DESIRED TEMPITURE IS REACHED. IF NOT IT WILL BURN UP THE UNIT.. this not a 4 sure fix but can get you up and cooling 4 free, or if this doesn't fix it the unit might be junk.. hope this was of help..klick yes
Jul 25, 2011 | Haier HWR08XC7 Air Conditioner
I have the Haier HWR08XC7 (8000 BTU) and my problem is that I have the thermostat set at 70 degrees, but it stays at 77 or 78 degrees... What could be the problem as the unit is 2 yrs old??
Hi!!
Check your owners manual, probably have unit set at automatic comfort level or some energy saver mode. It should say something on the remote about it.
Good Day!! Don't forget to rate this post!!
Aug 13, 2010 | Haier Heating & Cooling
Have an 8000 btu unit missing the vent hose
Home Depot carries alot of A/C parts that may work for you. Hope this helps 2rns4u <*{{{>(
Jul 22, 2009 | Danby DPAC8020 Air Conditioner
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
9000btu Haier portable air conditioner HPAC99ER doesnt blow cold air. What do I need to do?
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Jun 06, 2008 | Haier Heating & Cooling
Heating & Cooling Logo
272 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
