Inside fan to central air keeps shutting off, makes a ''thumping sound '' fan spins free, relay going bad?
  • 614 Answers
What kind of unit you have will designate what kind of relay it has. Goodman has fanrelay sequencer, Carrier and others have relays and fan boards. So it is one or the other . You will end up calling a service tech. There is only so far you can go yourself without knowledge of the system. Russ
Posted on Jul 23, 2009
Bryant central a/c working great, then suddenly inside fan not working, but outside unit on and pipe frozen.
sounds like inside coil froze due to low air flow. bad fan motor, fan relay,dirty coil or filter.
Sep 09, 2013 | Bryant Heating & Cooling
I HAVE A CARRIER CENTRAL AIR, THE OUTSIDE FAN IS BLOWING INWARD AND WON'T SHUT OFF WHEN THE FURNACE SHUTS OFF AFTER TEMP IS REACHED
Check the t-stat to make sure that the "fan" switch is st to auto. If not the fan is in the "on" position and is always on. Otherwise, It sounds like your "Central Air" is a packaged unit(Furnace and air all one unit outside the home) and the fan relay inside the unit is stuck. This need to be replaced. It is the rectangular unit with the leads from the fan motor attached to it.
Jul 29, 2011 | Heating & Cooling
I have a central heating and air unit. The unit
sunds like the fan bearings have seized up or u have a bad fan capacitor take a screwdriver and spin ith blade to where the air would be coming out the top and if it startswhen u spin it u need a fan capacitor
Feb 23, 2010 | Coleman Propane Forced Air Heater...
Intertherm furnace/AC, fan on the furnace won't shut off.
How old is the intertherm. The old ones have fan limit switch and sometimes they stick. The new ones have a fan baord or time delay relay. They go bad from moisture and they just go bad sometimes. It sounds like you just have a shorted relay. If you think you can replace it you can get a relay at any parts store. Need the model number of unit. If not just call a service tech for free estimate. Russ
Jul 24, 2009 | Heating & Cooling
Outside fan not turning
Either the fan motor's brushes are wearing out, or the relay is going bad. If there is power to the motor, than the motor is faulty.
Jul 02, 2009 | Ruud Central System Air Conditioner
My old trane air conditioner
Sounds like either a relay or start capacitor has failed, Sorry, but, this is a problem only a tech should approach. For safety reasons.
Jun 29, 2009 | Ruud Central System Air Conditioner
One unit runs a while, powers down, other unit blows transformer
you say it keeps blowing the transformer? you mean circuit breaker? if it is the circuit breaker, have the wiring checked for a short, if no short do a ohm test on the compressor. it may have shorted out internaly.
May 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Fan running constantly in the house
Check t-stat and make sure fan is set to "Auto", that might be why fan is running all the time, or it could be a fan relay that is stuck closed. It sounds like you A/C is over charged or you have a bad high pressure switch, this was a common problem with this manufacture especially in the heat mode.
Apr 24, 2009 | Ruud Central System Air Conditioner
Central air
Most thermostats have a setting for the fan called, "manual". That keeps the fan on continuously. The electronic thermostats can fail in a "fan on" condition. That would require a new thermostat. I also saw one air conditioner with a fan relay welded "on" by electrical surge. That would require a new relay.
Jul 20, 2008 | LG LWHD1800R Wall/Window Air Conditioner
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
