Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence Issue My television recently started acting up on me. It has green and red/purple looking lines at the bottom of my screen, and it's in the shape of a half moon. It is really annoying. About two weeks after my 3 yr warranty expired it started. I have searched on the web and the issue seems to point to some hardware failure due to heat. Well I live in the desert so I know for sure heat is an issue here. I just wanted to make sure I am heading in the right direction as far as diagnosis. Any help is appreicated.
  • 6 more comments
  • esc0
    esc0 Nov 21, 2007
    Terryfic,
    Thanks for the speedy reply. I can't believe how much the local repair guys are asking for to repair it.
    Now I haven't had the chance to open my tv and find the IC's as of yet, but does the old ones have the model number on them? And what's the difference between, STK392-110 & STK394-160E? Will my model tv work with either or do I need to replace the old ones with the exact same model?
    Thanks in advance for any suggestions.
  • joshwal Nov 21, 2007
    Terryfic - I am having the same issue but it appears I have the 120's. My part number is STK392 120. Do you recommend a different approach?
  • esc0
    esc0 Nov 21, 2007
    Terryfic,
    I finally got the board out that has the IC's.
    They are STK392-120's x2, which IC's do you recommend and which website can I order them at a reasonable price from?
    Thanks in advance.
  • esc0
    esc0 Nov 24, 2007
    Terryfic,.
    You around buddy? Waiting for your recommendations on what to next. Thanks in advance.
  • esc0
    esc0 Nov 24, 2007
    Terryfic,
    Thanks again for the speedy reply. I did a search on partstore.com and found the part number for $13.26 each. I have seen them for about 5-6 dollars on electronixonline.com but decided the more pricey on should be comparable to the OEM ones. Will update you when they come in and once I install them. Thanks again.
  • esc0
    esc0 Dec 01, 2007
    Terryfic,
    Thank you so much buddy. My parts came in Thursday and I got around to installing then yesterday. My baby is breathing again, she looks so beautiful. Thank you again for the help.
  • esc0
    esc0 Dec 06, 2007
    Terryfic,
    I need your inoput bud. My tv has been working great since I replaced the ICs. But not until today I have noticed a ripple like on the tv screen. It starts from the top and goes down the screen. It is not so noticeable but when I'm viewing a channel with a white or light back ground you can see it. You really need to pay attention to see it. It looks like a wave effect.
    Have you seen this? If yes what is it?
  • esc0
    esc0 Dec 06, 2007
    Terryfic,
    I popped in my transformers dvd and it doesn't seem to do it with dvds. It's only with my satellite cable. It didn't do that ever before and I have dishnetwork for 2 years now. I will monitor it some more and let you know at a later time.
    I really appreciate the time you've given me with my tv. Thanks and keep up the good work.
    Genius:
  • 1,694 Answers
You have a common occurring convergence problem = the
solution is: replace the convergence amp IC's ( both ).
Part # STK392-110 sub to upgrade STK394-160E.I use
Hitachi brand = no recalls.........................T.
Posted on Nov 21, 2007
  • 1 more comment
  • Vista Electronics Nov 21, 2007
    Locate IC's on large heatsinks = verify part # = 110's?
    Use upgrade to improve longevity, they are higher wattage....
    If they are 120's, let me know.........T.
  • Vista Electronics Nov 24, 2007
    Sorry for the delay....STK392-120 Use Philips only...part # is
    932212344682 = Try search for this # on web.........T.
    Remember = Generics have a much shorter life-span than
    OEM parts................
  • Vista Electronics Dec 06, 2007
    esc0,
    Hopefully, ripple is source problem......Tried a DVD yet ??
    joshwal,
    STK392-120 = 932212344682 Only.....................T.
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem, I think
i think you need a tech .because all the users adjustment were tried.
May 28, 2009 | Hitachi 57F500 57" Rear Projection...
Have a model 43A10 toshiba tv, has a purple color at very bottom of screen about inch tall. When i go into the menu, looks like writing is not lined up on the lower options of the menu. and partly up...
you either have a color purity problem or a convergence problem. purity can be effected by electro magnets in power supplys of audio amps and subwoofers too close to the tv
Convergence is the ability of the red green blue to drop on top of each other. can usally be adjusted via remote control. Please claify and repost.
Apr 03, 2009 | Toshiba 43A10 43" Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Green and purple band of color
*Screen Looks 3-D
*Colors wont align
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Help problems with Panasonic PT-47WX49
Can you post a picture of what your screen looks like and I will try an assist you with the problem.
Aug 09, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red and Green colors do no line up
It was most likely the convergence amplifiers. If you look up "convergence amplifier" on this site or google you will find lots of information. The part number(s) will be something like STK392-110.
I recently helped a friend repair this problem. If you are comfortable soldering it won't be too bad.
Nov 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
PT 47 convergence IC's? box? both?
Always suspect the IC's first, digital convergence prblems are actually pretty rare IC's go everyday. I'd check partsore .com Generics usually work fine, they are probably STK392-110's but check to make sure.
Apr 16, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
