Question about Dell Studio 1737 Laptop
I just want to eject a CD from my CD ROM and don't know which button on keyboard manually ejects the CD.
  • jmontgome474 Jul 23, 2009
    Thank you for your reply. How do I open "My Computer"?
  • Dell Master
  • 13,433 Answers
Dell studio 1737?
There should be a button on the drive that you can press and it will eject, or if the drive is stuck, there should be a small hole on the tray - on the front plate of the cd drive where you can push in a paper clip or similiar small pin to eject the drive mechanism.
Or, you can open my computer, then right click on the cd / dvd drive and select eject.
I don't know of any button combination or button to eject the cd drive. There are some programs that you can download and install, which might give you a shortcut key to eject the drive but I honestly don't think theres any build in feature for this.
but I can look into it more if your sure there should be one?
Posted on Jul 23, 2009
  • Ekse Jul 23, 2009
    My computer or "Computer" is on the desktop. or in start menu - computer.
Dv9815nr cd rom eject button
Yes there is. Open My computer and right click the CD ROM Drive icon and click Eject. This way you can eject your Optical Drive Tray.
Aug 10, 2012 | HP Pavilion dv9815nr Laptop
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
Can not eject cd rom there is message saying pxe media failure check cable connection
Thanks for your question.
First you can eject cd from cd rom buy using manual metal pick implement the hole and press. you know that every cd rom has hole. so you can eject cd.
2nd open your computer case and then open your cd rom carefully. then unplug cable and change it. new cable plug between cd rom and motherboard.
thanks.
Apr 17, 2011 | Lenovo Computers & Internet
CANNOT EJECT DISC IN ACER
every cd rom have a failsafe button should you have ejection issue. This usually a very small tiny hole normally next to the button that you need to press to eject the cd.
Please look for this small hole and use an office pin (which you need to straighten and insert it into the hole to eject the cd. This works even if the pc is off.
Good luck and let me know of the outcome
Nov 02, 2010 | Acer (91.49C37.001) CD-ROM Drive
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
How do i eject a stuck cd from gateway one 710 series I have tried the eject button on the keyboard but will not give it up...
Have you tried the eject button from the tray? If all that you need is a tool to eject the tray without touching the tower, I suggest you to go to this link and download the Eject-CD freeware runtime file EjectCD.exe - approx 30kB. Alternative if your tray is locked and can not open with the above methods, you have to locate a small hole in the front panel of the tray and put into that hole something like a connector (for papers) or a strong wire in order to push the internal system to open.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 08, 2010 | Gateway ONE GZ7108 All-in-One Desktop PC
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Cd-rom/dvd-rom door won't open
Hi!This is not a big problem...All you have do is take a pin, needle or something and just insert it into the small hole near your cd-rom drive..try this repeatedly while pressing the eject button..If it doesn't work you will have to unscrew the two screws on the right of your keyboard..doing this will give you the access to the cd tray and you can remove the cd and put it back together..
Nov 13, 2007 | Averatec 3200 Notebook
Dell Studio 1737 Laptop Logo
197 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
