Question about Kenmore Freezers
My Kenmore frig/freezer's shelf continually has a sheet of ice.
We've had a repair guy out 2x's and he said that this frig wasn't made for a part time/seasonal use and that it needs to be opened regularly. He replaced something each time but it's never been really frixed. It works fine and I just hate to spend money on a new unit if we can get to the bottom of this. BTW, we have been here and it is opened regularly and that doesn't make any difference?
Thank you
  • 459 Answers
I was told to check the doors gaskets when buying a fridge. The gasket must seal all around. Check by using a dollar bill. The dollar bill when placed anywhere along the door gasket must be held tight when the door is closed, it is held when you try to skip the bill off. If the bill is not held, the gasket is defective. This means there must not be any gaps letting air into the fridge.
A thin coat of ice means air is going into the fridge and moisture in the air freezing into ice.
Some doors flex and warp causing a bad gasket seal, or the gallery is bad. Just one probable cause for icing in the fridge
Posted on Jul 18, 2017
SOURCE: Ice build up in my frost free upright freezer
seems simple you have blocked defrost drain hole. find it and clear it out.
Posted on Nov 11, 2006
  • 237 Answers
SOURCE: kenmore upright freezer
Usually you shouldn't have any ice on the bottom unless something spilled etc. and froze. How all this basically works is... the cooling coils are where the brrrrr cold comes from but that causes frost/ice on the coils. About every 12 hours a little clock timer that runs continuously turns off the compressor and evap. fan then turns on a heating element that's under the coils. This heat runs till the defrost t-stat (clipped on the upper coil area) determines it's been warm enough that all the ice should have melted and turns off the defrost heater. Then everything returns to normal cooling until the next cycle starts again. As for the melted ice, that water drips into sort of a channel that funnels the water to the drain hole (should be just under the coil area). From there it goes down a tube to a holding pan near the compressor area in the bottom of the unit where heat from the compressor,etc. causes it to evaporate into the air long before the next defrost cycle puts more water into it. Sooo... check that your drain hole is open by pouring hot water down it and see if it flows fast out to the holding pan. Clean as needed.
Posted on Nov 30, 2006
  • 51 Answers
SOURCE: Roper--ice buildup on one freezer shelf
The reason for ice buildup is an air leak. Recheck all around the gasket by taking a dollar bill and closing the door on it and pulling it out. If you don't have resistance, you found your leak. Heat that area with a blow dryer to relax the gasket and close the door to let the magnet and seal set. Also, rub some vasoline on the hinge side gasket to keep it from dragging.
Posted on Dec 07, 2007
  • 1073 Answers
SOURCE: What can I do to get rid of frost build-up (more than 8" long & 1/2" Deep) on my NEW FROST FREE FRIGIDAIRE FREEZER GLFU2067F?
contact 1-888-77-lowes if you havent done this call, have them create a case file on this, tell the person that you talk to that if you try this solve and it dont fix the issue I want a new machine if they agree to this do the door replacement if they don't take it back to lowes
Posted on Apr 10, 2008
  • 158 Answers
SOURCE: sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Posted on Jul 01, 2009
Top shelf ices over
This could be because of the thermostat not sensing when the fridge reaches its set temperature and as a result of this the compressor will keep on running and build-up of ice will occur.Second cause of the ice might be the door rubber seal not sealing propperly.
Hope this helped.
Andre Nagel jnr
AQS Industries cc
Mar 29, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Drain plug freezes up and ice builds up in freezer then leaks into frig. How do you keep the drain free from building up?
Use a turkey baster filled with very hot water and flush it several times. That should resolve the problem. Also check the door gasket, if it is leaking, excessive frost would be visible causing more water then the system was designed to handle.
Good Luck,
Feb 28, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Coldspot / Drain plug freezes up and ice builds up in freezer then leaks into frig. How do you keep the drain free from building up?
suprisingly simple,thread a thin piece of string down pipe then tie a button on each end works great for cleaning out drainpipe.....
Feb 28, 2010 | Freezers
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
We have a Kenmore upright freezer. Ice develops
Sounds like you have a seal system leak.If you have got work done not long ago to the system it my be over charged or under charged.If no work ever done to it you may need a new freezer.
Sep 03, 2009 | Freezers
Kenmore frig/freezer, light/power on, no cooling in frezer.
looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Jun 15, 2009 | Freezers
Ice forming very fast on top shelf only
You said you checked the seal but one thing you can try to be double sure the seal is tight put a thin layer of vaseline along the entire seal it will fill in any gaps and you can be sure it is sealing completely.
Jan 05, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
271 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
