Question about KitchenAid KFP740 Food Processor
Light is on but blade will not turn
My food processor is new. I have only used it once before. Same problem at that time. Kept taking bowl off and replacing and it finally worked. Same issue this go around. I have taken the bowl off and replaced it a dozen times and nothing except the light works. Please help!!
  • 120 Answers
You have a bad sensor switch, when you put the bowl. Locate the sensor switch and replace it.
Posted on Jul 23, 2009
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Jan 03, 2015 | KitchenAid Food Processors
In need of Bowl and blade
GENERAL ELECTRIC FOOD PROCESSOR MODEL 106622F WORK BOWL
I was able to locate a bowl for the 106622F processor on E -Bay. You may be able to find a blade on E-Bay. From what I gather, there is no source for replacement parts, other than used parts. I hope this helps ! Good Luck....
Mar 31, 2014 | GE 106622F Food Processor
My daugher set the food processor bowl on a hot burner. We tried to melt it back into shape but that didn't work. I can't find a web site for replacement parts. Is it easier just to buy another?
You didn't specify the make or model of your food processor, but you should be able to find a replacement bowl. Abtecparts.com or PartStore.com are two places that you might look. However, you might find that a new bowl costs almost as much as a new food processor. Good luck!
Dec 12, 2009 | Black & Decker FP1300 Quick N Easy Food...
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Motor works but will not turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl asssembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Motor won't turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Jul 15, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart food processor DLC 8 Plus - can't unlock new bowl
I just had the same problem! I gently tapped the the bottom of the handle with a hammer in a clockwise direction. It finally unlocked and is now working fine. Good luck!
May 11, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Wont run
If you try the instructions below, and the motor test fails, you can send it in to Cuisinart for a trade-in, but the trade-in will be just as expensive as getting a new food processor (unless your product has an extra-long motor warranty):
-Tha Mp3 Doctor
Sep 16, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
KitchenAid KFP740 Food Processor Logo
431 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Shehu Pro
Shehu Pro
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
