Question about Cell Phones
I have a motorola FX-853, the mather is the keypad does not work. I try to find how to solve the problem
Touchscreen keypad on xprt not working
My Dear Your Phone Keypad Ic Default So Please change Keypad IC
And Keypad Problem will Solved
Dec 11, 2012 | Motorola Mobility XPRT
Key pad not working in my motorola l7
My Dear Your Phone Keypad IC Fault So Please change Keypad IC
Oct 23, 2010 | Motorola Mobility SLVR L7 Cellular Phone
The buttons of my casio cfx-9850GC plus ( buttons f1,f2,f3,f4,f5,f6) dont work. What can I do to solve my problem???
First of all check its warranty, if exists, concern the authorized dealer or representative. If not unscrew your calculator and clean keypad with a wet white cotton cloth by rubbing gently you will see black spots on the cloth. place the keypad at where it was placed previously. You will find it working as usual. INSHALLAH.
Oct 08, 2010 | Casio FX-9750GPlus Calculator
My phone got wet
ur mobile keypad might got slight damage... since it got wet.... u can go to th authorised service centre for motorola an get ur keypad service.... so that ur prob get solved..... kindly rate me .... thank you....
Jul 01, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Keypad does not work on cellphone, joystick does. Sony Ericsson W200i
Your keypad is not working that means your keypad IC may have some problem or you can do this...
Open your phone & clean your motherboard with Carbon Tetrachloride using a toothbrush slowly. It doesn't harm your phone because it solves the dust problem.
May 01, 2008 | Cell Phones
Outer keypad of motorola A630 does not function properly.
take the phone and have the keyboard (Outer) replaced or service.
Jan 24, 2008 | Motorola Mobility A630
Motorola V3m keypad problem
open the phone and clean the keypad connector really good
Dec 11, 2007 | Motorola Mobility RAZR V3
Motorola ROKR e1 keypad problem
It's the problem with the keypad board, the hardware problem not software, clean the connector carefully and replace the keypad board with the new one. This will solve the problem. Regards.
Aug 23, 2007 | Motorola Mobility ROKR E1 Cellular Phone
Motorola v6 keypad issues
Your phone possibly got wet and thus your screen flex cable connection needs to be cleaned up with some contact spray or maybe your flex cable needs replacing to solve this problem.Contact a good service tech to get this problem rectified. At least you know what your problem is so now you could get it solved. Sam!
Jul 13, 2007 | Motorola Mobility MOTORAZR maxx V6...
Keyboard only partly working
Um check and make sure that behind your keypad and see if there not blocked by dirt or something with your connection although your need tabs to check and see to get of your keypad but be carefull if you dont know what your doing and aint got insurance dont do it, i also think there is a solved problem about opening the keypad up. Hope that helps.
Feb 11, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
258 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
