Question about Grilling
Hello: my Webber grill is 2 years old. It ignited in flames last night destroying the whole unit. Am I covered with some kind of warranty?
  • 5 Answers
It depends on the issue contact customer service 800-446-1071
Posted on Mar 27, 2017
  • Grilling Master
  • 3,238 Answers
Possibly not after two years . I would think not if it went up in flames .
We have a 3 week old Webber Q220 and the ignition does not work - plenty of gas but no spark
Sorry bout your luck. I have a webber. Cheaper modek, and it does the same thing. I.leave my lid closed ...turn it on wide open wait 30 seconds and start lighting.
Jan 01, 2014 | Weber Q Grill
Insulation gone in Jandy Lite 2
need new heater that one is unsafe
Jun 02, 2013 | Jandy Pool & Spa
Two things....I changed the tanks out last night and I can't get the burners to light. Full tank of gas as I checked it. Took the burner covers off and cleaned the burner pipes itself and still nothing? ...
Replace the regulator to get your burners to work you can get that at Home Depot, call Weber to get the other part, if your grill is under warranty you may get it Free!
Aug 15, 2010 | Weber Genesis E-310 Gas Grill
The first burner seems to burn very low and not very hot
If it was me, I would,first try to clean them and see if that improves the flames. During the course of cleaning you can determine if the burners are corroded and needing replacement or just caked up and dirty. Are the burners stainless steel or cast iron? Cast iron lasts longer, and tends to get smaller in flames when it's seams corrode shut. Plus it is easier to clean. Stainless steel tends to corrode and fall apart, causing flare ups and unsafe use. Douglas
Jul 05, 2010 | Barbeques Galore Turbo STS 4-Burner...
Weak flame on webber q200 grill
Remove connection to tank, reconnect, open valve slowly, when you open valve to fast the tank valve has a shutdown in it, it thinks something is wrong and shuts valve down. Always open tank valve slowly when using.
Also your tank valve could be sticking causing this problem, to fix replace tank.
Feb 25, 2010 | Weber Q200
Flame is low
try opening the tanks slower so the overfill protection device in the tank won't kick in and restrict the gas flow.
Nov 10, 2009 | Weber Genesis Silver A Grill
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
KENMORE Gas Grill 141-152210 Kenmore 437 sq. in cooking will only heat to 250 degrees
sudsy, this exact same thing would happen to me every time I changed a tank. I know it's nothing to do with the grill itself. I would have to seat and reseat the regulator hose to the tank a couple of times before it would start heating normally. Your model has 3 burners and I suspect that the flame is real low on each one even on the high setting. Try connecting and disconnecting the tank a couple of times and see if it comes to life. If worse comes to worse you can order a new regulator hose. Part number P3632L. Catriver..post back.
Apr 03, 2007 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Grill Blew up
Yes...........I just had my grill go up in flames as you discribed. The gas hose fitting is a crimpedconnection that connects the hose to a small male fitting. This is not properly enginered ... there should have been a brass conection there. JT
Aug 26, 2006 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Grilling Logo
261 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
