Air Conditioners
Problem for DeLonghi Air Conditioners
Generic problem for all DeLonghi Air Conditioners
Heat pump seems to be blowing alot of col...
By tglover on Jul 23, 2009
Heat pump seems to be blowing alot of cold air and making more noise than it usually does
Solution #1
posted on Jul 23, 2009
Not Rated)
james3751
Rank: Guru  Air Conditioners  Expert
Rating: 91%, 201 votes
Most of the time when a heat pump starts blowing cold air it is low on refrigerant or **** in one cycle or the other. Try to switch from heat to cool several times. If this does not work you will ahve to call a service Tech . there is only so much you can do. Russ
Was this helpful?
Yes
No
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
no problems. Just what is the amps on the 13,500 - model # 59516.741. Thanks.
Answer
I have an Intertherm EP1500 portable heater. It's 7 foot long exactly, 120 Volt, 1500 watt.... (More)
Answer
does my hampton bay unit blow heat
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioners Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
