Question about King Post AC-9000RH Air Conditioner
Does it remove water through the exaust vent? if so what setting? may download ownerts manual? where may get window vent adapter?I never received an answer!
  • 19,396 Answers
Water is not removed through the exhaust vent. It is either conveyed into an internal reservoir or evaporated.
Manuals for this specific model are not available.
Posted on Dec 09, 2009
What can I do to fix error code 13 Paloma tankless water heater PTG2-42PVN
The error code 13 indicates that the PTG2-42PVN is not getting enough air or the vent termination is blocked. Check both the intake and exhaust termination for blockages and remove any debris. Make sure that you have good air flow in the room (no other vents should be blocked). Clean any other blocked vents. If you use a fireplace or space heater in that area, open a window or vent to increase the oxygen levels in the room. If other appliances are used in the area, make sure that they aren't affecting the ventilation and oxygen levels in the area. If you bring in air to the water heater from the outside, make sure that other appliances aren't exhausted to that area.
ManualsLib has the manual for the PTG2-42PVN: https://www.manualslib.com/products/Rheem-Ptg2-42-Pvn-Pvp-330558.html . The error codes and solutions are listed on page 33: https://www.manualslib.com/manual/140606/Rheem-Ph-16-Fisn-Fisp.html?page=33#manual .
I hope this helps.
Dec 18, 2016 | Water Water Heaters
Hinged exaust door on top of microwave only partially opens then repeatedly and rapidly bangs open and closed
The service manual for that model is here.
It may be a bad limit switch / detector switch in the louver circuit or there may be a bad cam in the louver.
There's a YouTube video available showing how to remove a typical over the range grille (and if necessary) control panel assembly in under 5 minutes.
Some additional info on disassembling louvered models:
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
(There are three L-shaped clips that fit into a slot to hold bottom of the vent)
Then remove one screw (which holds the control panel in place) near the top of the control panel.
Once that screw is removed the panel tilts out so you can disconnect the wires and then slip it out.
Be sure to mark and/or photograph your wires so that each one gets back exactly where it was after the repair.
Reassembly is accomplished by sliding the L-shaped keepers in place, then sliding the vent grill to the right and pushing it into place.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 30, 2013 | Samsung SMH7178STD Microwave Oven
Gateway m-6867 windows will not start, gets hot shuts down before restore finishes
Hi abtmc1...
Sounds like your over heating is caused by a faulty fan, or dust in you Notebook.
Sometimes you can clear the dust from the fan and it will be ok...get a can of compressed air and blow into the computer exaust vent to try and remove the dust...if that is the cause of your over heat problem...otherwise you have a faulty exaust fan that needs replacement
Please take time to rate me
Sep 05, 2011 | Gateway M-6867 PC Notebook
Dryer is blowing cold air out vent and not drying clothes
Could be the heating elliment..
One way to check --
remove the exauste hose..
Put a mirror to see into the exaust hole & try to see the elliment(s)..
When on - they glow hot like a stove burner..
If the elliment is not glowing - it needs replacing..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Dryers
I love the functionally and efficiency of my Rinnai water heater, however, we smell funes in our bedroom after hot water usage .. our bedroom is right above the area in the basement where the water heater...
The unit is a completly sealed unit. which uses combustion air from the outside & exausts to the outside. check for leaks on the exaust pipe with soapy water while running. if you see bubbles , theres the leak. if not, the exaut may be getting sucked back into the house through a window or other opening to close to the exaust.
Jul 01, 2009 | Water Heaters
Exaust vent/ fan very weak
In your duplicate post, you mentioned your model, so here you go:
This is due to poor air flow, either to a blockage or a problem with the internal cooling fan or hood vent exhaust fan.
Are the grease filters or charcoal filter clogged?
You may want to check your owner's manual for info on checking the filters. Grease filters can be cleaned, but charcoal filters must be replaced about every 6-12 months.
The installation manual will tel you if there's some error in the installation setup.
You can download Maytag owner's manuals and installation instructions here.
Dec 10, 2008 | Microwave Ovens
Exaust fan has weak suction on maytage mmv4205baw
Dec 10, 2008 | Maytag MMV4205 Microwave Oven
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Belking wireless adapter install
when you are advised to connect the usb adapter, it will recognise it, then the usb host controller is installed to recognise the adapter,but it should continue to instal the driver and then recognise it as Belkin 54g, if not, then you need to keep the cd rom in and then force it to install the driver from your cd drive, but it may not be compatable with ME unles you have a windows 2000 driver.
When the installation is complete you should in any case have the belkin software icon on your desktop to set up the adapter, if not then the software has not installed fully.
It will also be listed in add/remove programmes if it's fully installed.
Sep 22, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless 3crusb10075 problem
Sounds as if your router may need to be set to enable wireless connection and enable DHCP, this alocates your wireless adapter an I.P Address automatically. If this is alraedy the case, check the properties of your adapter to see if it's set to recieve I.P address automatically. If still no joy find your routers I.P. address and DNS address (this is what you type in your web browser to set it up). If your router is 192.168.2.1 or similair, set your adapter at 192.168.2.2 and the same DNS address normally 255.255.255.0. Restart both pc and router and try again. Also make sure network sharing has been set up via the XP wizard.
Dec 14, 2006 | 3Com (3CRUSB10075) 802.11g/b Wireless...
King Post AC-9000RH Air Conditioner Logo
Top King Post Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a King Post Heating and Cooling Expert? Answer questions, earn points and help others
