Question about Whirlpool Duet GHW9150P Front Load Washer
F02 error and suds errors no drain hose problems ..
Thank you for the comment about the drain under the front door of the whirlpool duet washer!!!! My drain was clogged too. It would have been nice for the company to include this information in the manual; however Fixya .....fixed my washer! Thanks again.
  • 15,935 Answers
No Problem - Glad we could help!
Thanks for using FixYa!!
Posted on Jul 23, 2009
I Have Probleme whit my Whirlpool (SUD F02) Thank you
It sounds like you have a Whirlpool Duet instead of a Whirlpool Cabrio as the codes indicate a draining problem. Press Pause/Cancel twice to clear the display then unplug the machine. Remove the screws attaching the bottom front panel then pull the panel down and off. Prop up the front bottom edge of the washer or cushion and lean it against the wall to access the screws more easily.
Place a container or a piece of towel underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the drain filter by turning it counterclockwise and clean it.
Click on the link below if the problem persists after cleaning the filter.
Kenmore Elite and Whirlpool Duet Sud/F02 Error Code
Jul 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet flashes F 02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch. Ensure the hose is clear by blowing into it. If the hose is clear I recommend replacing the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02
F02 error and not draining correctly (pool of water left at the bottom of the washer after cycle has completed). This is on a whirlpool duet front loading washer.
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
• Check the drain hose and make sure it is not plugged or kinked.
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects.
• If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 01, 2011 | Whirlpool Washing Machines
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin out water, shows F02, already checked the hose for kinks and/or clogs?
Potential Causes
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer has a (suds) code message and sometime f02 thank you
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!#$%
Aug 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
200 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
