Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D
Compressor working, use to make sucking sound when I close door, now has ice on back wall and not freezing completely.
  • 2 more comments
  • buterfly444 Jul 23, 2009
    model FFU11FK2AW3 SHOULD I unload freezer and deforost by unpluging not sure where drip line is to check for blockage
    Model FFU11FK2AW3
    Fan is working unable to see coils as they are behind a plate
    WWil work through list of steps will get back if need more help thank you
  • 15,935 Answers
Is there ice around the evaporator coils inside?
Is the evaporator fan working?
Have you unplugged for a few hours to defrost?
Please also verify the exact model # So I can help you more precisely with parts etc.
Thanks
:D
Posted on Jul 23, 2009
  • blueextc3221
    blueextc3221 Jul 23, 2009
    CLICK HERE to see an expanded diagram of your freezer.
    The drain line is #29.
    Yep - you'll need to empty the freezer to totally thaw out the coils.
    If they are encrusted with ice - chances are the defrost timer has failed.
    It is #23 on THIS EXPANDED DIAGRAM
    Or #20 the thermostat.
    That part you can see HERE.
    Or the defrost heater. #14.
    Before throwing money blindly at the freezer - each component should be tested.
    If you want more help - just let me know - or simply re-post a new problem (ie - how to test freezer timer etc.)
    Please accept this answer to remove it from the work queue.
    Thanks for using FixYa
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Freezer door left open will it work again?
yes it must be shut off and completely defrosted.with doors left open it usually takes about 2 days. what happened if you look at the back wall in the freezer from the inside you will see a bunch of ice and there is more behind that panel you are looking at. it froze up the coils so that no air will get through them. good luck rich
Sep 18, 2012 | GE 20.3 cu. ft. / 575 liter Upright...
My kenmore is not pressure sealing
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
May 15, 2017 | Kenmore Elite Side By Side Refrigerator -...
Iam working on a hoshizaki ice maker, turn it on make one batck of ice, after that, my cooper lines on bottom of coils were warm and o n top od the coil were hot,whar could be the problem?
On Hoshi ice maker, if coils are HOT, it is passing hot gas from compressor into the lines. After the defrost of the first cycle, after this cubes are completely cleared from the plates, the "Hot Gas Valve" should close and the freeze cycle should start over. It sounds that the valve is sticking open and not stopping the hot gas from entering. Look there first.
Sep 10, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have ice buildup inside the door and on the shelves inside, and on the bottom. The compressor is running and the temperature is fine, everything freezes. The ice that forms is crystalized around the...
all you can do now is, slitly twist the freezer door. open the door an twist in twards the slite crack side. don,t over do it. a dollar bill, should be able, to be held in place, between the seal. then you will know you have a good seal. Don't tuch the hinges!!
Jul 03, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Sub zero refrigerator model 532 problem the freeze is warm on the top but the ice & items below the ice are OK. i suspect that the light may be always on. also the freezer door does not make its...
I suspect a bad fan motor, door switch, or not defrosting.The suction when door closes is caused by the low temperature created when working properly.
Feb 14, 2010 | Freezers
The compressor on my refregerator seem to be overheated it is a side by side the insides of the doors are warm and the freezer will not free but it is running there is cool air in freezer
The doors should be warm. There or heaters in the doors or what they call a yodelers loop in the frame around the doors that keeps condensation from forming. Make sure the fan if blowing on the compressor and the fan inside the freezer is also running. If so be sure there is no ice built up on the bottom inside back panel of the freezer. If so you will have a defrost problem and the coil is full of ice and not allowing the air to flow through it and cool the fridge. If there is ice, the heater behind the panel is most likely bad.
Dec 21, 2009 | Whirlpool Freezers
Upright Freezer self defrosting
THE (SUCKING AIR) OCCURS WHEN THE TEMP IS VERY LOW IN THE FREEZER AND YOU LET WARM AIR IN BY OPENING THE DOOR. WHEN THE DOOR IS CLOSED, THE WARM AIR IS COOLED CAUSING A VACUUM IN THE FREEZER. IF THE DOOR SEAL HAS A LEAK AROUND IT, THE SUCKING SOUND WILL NOT TAKE PLACE. CHECK THE DOOR SEAL FOR A GAP AT ONE OF THE CORNERS OR ALONG THE SIDES,BACK, BOTTOM, OR TOP.IF THE SEAL IS O.K., HOW IS THE TEMP? IF THE TEMP SEEMS WARM, YOU MAY NEED TO CHECK THE SEALED SYSTEM. LOOK AT THE FROST PATTERN ON THE EVAPORATOR. IS IT COMPLETE AND UNIFORM? IS ONLY PART OF THE EVAPORATOR FROSTED BACK? IF THE ENTIRE EVAPORATOR IS FROSTED BACK UNIFORMLY, THE SEALED SYSTEM IS O.K.
Apr 01, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Open Questions:
See all Frigidaire 13.7 cu. ft. / 388 liter Upright Questions
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D Logo
73 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
