Question about RCA Televison & Video
I want to know if my tv has a built in tuner - RCA Televison & Video
  • 118 Answers
Make and model of you TV?
Posted on Jul 23, 2009
Do you know if the Visione VISLCD2408 TV has a BUILT-IN DIGITAL TV TUNER or does it only have a ANOLOG TV TUNER ?
If you can tune digital channels directly, e.g., 10.1, 29.2, the tuner is built in.
Jul 08, 2016 | Televison & Video
Model c-13910. Does it have a digital tuner?
most crt tv's such as this do not have digital tuners built in and would require a set top box to receive digital signal i know that in Australia where i am we no longer use analog signals so all tv's must have a digital tuner or set top box in order to still work
Nov 03, 2015 | JVC Televison & Video
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
Does my Insigna Tv Model number NSFTV27, serial number 065260705675 have a built in digital tuner? Also, what kind of antenna should I get for this model?
Hello
Your Insigina TV has no built in digital tuner. It has VHF/UHF/CABLE IN tuner. It is not a digital one. OK.
Jun 13, 2011 | Insignia NS- 27" TV27 TV
How can i tune my tv in to recieve freeview channels?? tried everything with no luck. cant even get analogue channels? i know this isnt a problem with the aerial as other tvs work!!
In the US, you are not able to obtain free HD channels without a tuner and an antenna. Some HDTV's have built in tuners and depending on your location to the broadcasts, you may be able to obtain reception. It is possible that one of your TVs has a built in tuner if it is newer and this other TV does not. Analougue channels no longer exist as all channels have been converted to digital broadcast and would need to be converted if trying to view through an analogue TV. Thanks.
Feb 28, 2011 | Televison & Video
Could you please let me know if i can use my viewsonic monitor as a tv if so what cord do i need to get
The monitor does not have a built-in TV tuner and cannot function as a TV unless your computer has a TV tuner. In this case all you need to do is connect the monitor to your computer and start the TV tuner/program in your computer.
Jan 11, 2011 | ViewSonic VX2235wm LCD Monitor
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Is my tv digital compatible or not
https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
