Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Won't cool any more
My fridge turns on, but it won't cool.
    Sergeant:
  • 202 Answers
What do you mean turns on. The light inside is on. Do you hear the compressor coming on. If you hear the compressor turning on and the fridge doesn't get cold, compressor might need freon. If compressor doesn't turn on, your timer is not working
Posted on Jul 23, 2009
Fridge light won't turn off..does that mean the fridge has stopped working or only the light needs to be fixed? Can tell it's not cooling as much as it used to.
The light is usually a seperate circuit to the fridge compressor and it staying on is more likely to be a faulty switch than the fridge not working. Open the door and look around the perifery of the door opening, there should be a spring loaded plastic part that pushes in when the door is shut and springs out as you open the door. Try manually pushing it in and see if the light goes off, if it doesn't then the switch behind it may have become dilogded in it's housing or broken. Turn off the power to the fridge, unscrew the housing, re-position the switch or replace it, re-fit the housingturn on the power and test.
Jul 02, 2013 | Frigidaire Refrigerators
Freezer works not fridge
move the temp sensor see side of inside of fridge
Jun 24, 2013 | Dometic RM2652 Refrigerator
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
Refridgerator is not working will not get cold
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacume cleaner stops working when the bag is filled with dust and fibers.
The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air movement from back to front (or visa-versa) of your fridge will slowly (years) prevent how good it cools. The build-up of dust and cobwebs prevents your fridge from cooling (more specifically prevents the heat to disapate from the metal heat disipating fins attached to the metal tubes to be blown off by the fans air). OK! Remedy for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge manufacturers do not provide a dust filter like the vacume cleaner and central air systems manufacturers do. You have to figger out the best way you can clean it. Possibly vacuum with a crevice tool, or use a small brush than vacuum. The extreme would be unplug the fridge ( so you won't get electrocuted) bring a water hose into the kitchen and spray water at cobweb buildup at the bottom fridge, than wet vac the floor then wait 20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air.The fridge
May 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freeze and ice maker quit making ice and prevent it to keep food frozen
Here is the basic idea on how to keep the refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved by an electric fan or blower in order for that product to work properly. If air movement is blocked the fridge won't get cold, the central air conditioner won't cool enough, the vacume cleaner won't clean as well. Check on your fridge's air movement by inspecting the bottom of the fridge for dust and cob webs. Remove the front bottom clip-on plastic grill. Or also even access the lower back of the fridge by removeing the screws holding up the heavy cardboard cover to see inside. Blockage of air flow will prevent a fridge from getting cold. Just like a vacuum cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and fibers. Look under your fridge if it is cloged, it will look just like the stuff on a dirty central air filter.
When you stand in front of your fridge and you hear the fridge electric motor turn on, the fan will blow air out the bottom.The fridge
May 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge running warmer than it should, Cooling fan on back doesn't turn, the compressor/condensor running very hot , and no new ice being made. Cleaned the cooling grid which was full of dust.
Apr 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
364 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
