Washing machine won't spin
I have a Whirlpool Stylemaster 4217141 and it won't spin. I understand that it could be the belt, but I'm not very mechanical and not sure what bolts or screws to remove from the back of the machine. Please help.
Eric Knoxville, TN
    Sergeant:
    Novelist:
  • 197 Answers
I think it's the capacitor. The capacitor live under the top of the washing machine, two screws, and measures about 7"x2". The capacitor gives the drum An extra 'bump' when all the weight is in It. Remove the capacitor with a pair of pliers or a spanner but under NO circumstances, touch the two connections at the to of the unit, you will get one hell of a shock! Run the machine empty with the top off and it should run properly.Then refix the top. Job done,
Posted on Jul 23, 2009
Whirlpool stylemaster 4217141 water won't stop filling the machine and it wont start agitating
drain machine and check the water level pressure switch air pipe
that's connected to it ,it's posably blocked stopping the switch from operating. safety disconnect from mains electrical supply before removing any covers.
Nov 13, 2016 | Whirlpool Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
a new dampener may be needed, but check to see if the ballast weight is still attached. ive seen this happen before
May 03, 2014 | Washing Machines
Whirlpool stylemaster 4217141 rev
Try cleaning the lint filter on the bottom of the inner opening. Lift up and clean filter.
Oct 15, 2013 | Washing Machines
I have a Kenmore 90 Series washing machine Stylemaster 4217017. It quit spinning tonight. How do I fix it?
Possible that the belt or the drive or the spindle assembly is the suspect. Click this link for tips to reset: Drum Reset
Jan 19, 2013 | Kenmore Washing Machines
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Spinning doesn't take place during spin cycle
One possible problem is the door interlock switch. This switch prevents spinning when the door/lid is open. If the switch is bad (open/off all the time) it sends a false signal that the door is open and washer will not spin.
Does the machine just sit there when it's not spinning or does it sound like it's trying to spin but can't?
Apr 21, 2009 | Washing Machines
I have exactly the same problem as Jonthan, what's the solution?
Dec 24, 2008 | Washing Machines
Washing Machines Logo
436 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
