One way That I can think of is burning the video on a DVD or Blu-ray disc and then play the disc on your TV through a DVD or Blu-ray player. Here is exactly how you can burn a video onto a DVD/Blu-ray disc How to Convert and Burn MKV to Blu ray with Subtitle
First thing I would check is Internet connection on the smart tv that won't connect. If that doesn't work try downloading new software for Netflix. Try those and see what happens.
Sep 18, 2014 - Check graphic card software on laptop to make sure it's on the right settings to output image to TV ... Just turn off the cable box,when u used the TV ...
smallbusiness.chron.com > ... > Setting up a Business
Streaming media on Netflix results in a reduction of the DVDs cluttering up your entertainment center. ... A wireless connection requires you to turn on the televisionand media player to follow ... How to Set Up the YouTube App on a Vizio TV.
Sounds like the CPU froze. Unplug set from power completely, then plug back in, should work. If not then the problem will have to be solved by a repair technician.
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are... 1) Exit the VizioNetflix App. 2) Physically connect an Ethernet cable to your broadband (just temporarily) 3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection) 4) Start the VizioNetflix App 5) Click OK to start the Netflix App 6) You should now see a different screen that gives you the Netflix Activation Code. 7) On your Computer, Login in to Netflix, 8) Click on "Your Account & Help" link on upper right corner 9) Scroll down to Watching Instantly on your TV or Computer section 10) Click on Activate a Netflix Ready Device 11) Enter the Activation Code shown on your Vizio TV and click Activate 12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue. 13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV. 14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again. 15) Use your Netflix App and this time it should automatically connect via WiFi note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
