Question about PNY Optima Pro 2GB Secure Digital Memory Card
My card is full of pictures but none of the pictures will read on my computer or my camera...what should i do?
    Novelist:
  • 117 Answers
Okay if you need to recover there is a program called ZAR that will allow you to still read and recover the pictures, it may rename them but you can still recover them. i use this program all the time for failed memory cards or hard drives
http://www.z-a-recovery.com/
thats the website, there is a trial version
its worked for me so Good Luck!
Ruben
Posted on Jul 23, 2009
How do I clear the memory on the t1031 Polaroid camera? It took 3 photos then said memory full. How do I get more photos on the camera? There are none stored on it, only the last three I took.
If you do not have an sd card, the camera only allows a few pictures. If you do have an sd card, it might be full and the camera is not reading it all. Best way to check is plug it into the computer and see that way. Other than that, you might want to format your card.
May 15, 2011 | Cameras
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
Reads CARD FULL, can't view the pics, reads NO IMAGE
Sounds like the card has died. unfortunatly this can happen. and could be caused by a number of things including static.
you can maybe try a disk repair in windows.
hit your windows key and press r at the same time. in the command line type CMD and hit enter, it will open up a DOS window. type CHKDSK ?: /f where teh question mark is, is the drive letter that windows has assigned the card when you insert it. if it is an error that is repairible this might work.
Sep 23, 2009 | Olympus SP-560 UZ Digital Camera
I uploaded my pictures from my memory card onto the computer. When I put the card back into my camera, the camera won't read the memory card and it says the internal memory is full (12 pictures). How do...
If you indeed have the pictures on your computer (and are safely stored)... you might try selecting the format memory card function in the camera, to reformat the card, in case it was somehow corrupted while connected to the computer.
Aug 09, 2009 | Kodak EasyShare M853 Digital Camera
Memory card reads full
What size card is it a plain SD or MMC? is it less than 4 meg? is it 2 megs or less
2 meg or less it needs to be formatted. It is 4 meg the camera will not read it.
It happened to me on a Z740
Jul 24, 2009 | Kodak EasyShare C310 Digital Camera
My fujifilm finepix s700 is having problems reading the sd cards i put in none of them are new and have worked before but when i put them in and go to playback it says there is a read error and i cant...
I had the same problem, First, format the card with the camera, you can't drop the card into a computer, because after you format the card it will only work in the camera. If its formated with a computer, then the camera can't use it. You will have to connect the camera using the USB cable to transport your pictures to the computer, use 2GB class 6 cards, the high end 4GB XSD cards will not work at all.
Jun 09, 2009 | Fuji FinePix S700 Digital Camera
Camera card said it is full
Does the memory card have a 'write-protect' lock on it? on an SD card this is a small plastic lever on the top right edge.
Have you tried to format the card with the camera?
Can you read and write to the card with a computer and card reader?
Does this card work in any other cameras?
Dec 11, 2008 | Kodak EasyShare C330 Digital Camera
Sd memory card- on camera reads card error I took some pictures off my computer put them on my SD card to view in my camera. They are pictures I had take on the same camera, but I am getting read error....
sience they are on your computer try to format the card with the camera. see if you still get the error if you do then try a diffrent card if the camera is still having the issue then you problem lies in the camera's card reader writer. and the main board might need to be replaced. this can run any where from 75.00 and up depending on the full issue. please if you need any further help let me know.
Nov 26, 2008 | Fuji FinePix Z10fd Digital Camera
Why does the camera Ready light glow steady red?
The cause and solution may include one of the following: The camera internal memory or card is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The camera processing memory is full. Wait, and resume picture taking when the light turns green. The card is read-only. Change the storage location to internal memory or use a different card.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
PNY Optima Pro 2GB Secure Digital Memory Card Logo
208 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
