Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
I am looking for the service manual for toshiba 5h84
Want to clean lenses and calibrate
  • 261 Answers
The model number doesn't appear to be correct. it seems you have either a 57" (57H84) or 65" (65H84). However, the manual is the same for both models.
If you have Adobe Acrobat reader installed, you can view the manual for either set at the link below.
(Right-Click/Save As to download)
http://www.tacp.toshiba.com/tacpassets-images/models/57h84/docs/57h84_om_e.pdf - Manual
Posted on Jul 23, 2009
My toshiba is saying bad disc what can i do
Whether this is a stand alone dvd player or an optical drive on your computer it may need to be cleaned. If it's a laptop where you can see the lense as you pull out the tray that'll be easy to clean: use a lint free/low lint cloth or paper towel or qtip and put a few drops of clear rubbing on the cloth or qtip and gently clean the lense. If the lense can not be seen you'll a lense cleaning disc and cleaning solution (aka rubbing alcohol). Attached is a link from Expert Village showing how easy it is to clean the lense with the cleaner. Good luck! How to Clean Personal Electronics How to Clean Personal CD DVD Players
Aug 10, 2016 | Toshiba Televison & Video
It is fuzzy when it first comes on and then just not as clear as it was before. can i open the back and clean it or will that make a difference?
Cleaning won't help unless you have reason to believe it's unbelievably filthy inside, which is generally not the case. Plus cleaning the screen and/or lenses may make things worse if you aren't experienced. Many sets have a "magic" or auto focus procedure they can run on themselves to calibrate themselves periodically. Check your Owner's manual if possible, or look for a button that says something like "focus". This process takes several minutes, do not interupt it once started... good luck.
May 29, 2011 | Mitsubishi WS-55411 55" Rear Projection...
I have a Toshiba U300-15P running Vista. The DVD/CD drive will not read any CDs but will read DVDs! Any ideas?
hi..try to clean the lense of CD/DVD player if you a CD/DVD cleaner or try to clean a lense using a cotton buds....Thanks..Good Luck..^_^
May 13, 2009 | Toshiba Computers & Internet
Toshiba 50H81 access to lenses
Hi Dan,
I emailed you 2 ideas, how to get approach lenses for focusing.
Hope that would be helpful to you.
Dec 07, 2008 | Sony KP-51HW40 51" Rear Projection...
How about ru-52sz51d ?
I've dealt with DLP projectors and TVs for over two years and never had to send out a technician to calibrate after a bulb replacement unless of course the light engine has been jolted out of position. You may be looking for more than just a calibration, you may need repair service. Calibration was common with front/rear projection TV's when they used 3 lenses. DLP only uses one so other than focus and color adjustments, regular calibration shouldn't be necessary unless something is wrong inside.
Aug 24, 2008 | LG 42PX4DR 42 in. Plasma TV
Afficio 450 camera lense alignment
You need a manual to calibrate the scanner do you have one?
There are some holes in the scanner that need to be calibrated with a tiny screwdriver. The manual teslls you the correct settings.
Did yiou remove the cable?
Aug 19, 2008 | Office Equipment & Supplies
My cd player use to play mp3 disk and now only plays regular disk.
needs some little calibration of the lense,that why its like that..
Jun 22, 2008 | Toshiba Audio Players & Recorders
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
Movie skips and freezes during play
CD and dvd disc cleaners will not solve the problem, a deeper and delicate cleaning procedure by cleaning the lens manually with an cotton swab is needed...
Although the quality of newer discs is to be discussed.
Oct 09, 2006 | Toshiba SD-V392 DVD Player/VCR
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
520 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
