Question about LG LRSC-26922 Side by Side Refrigerator
Problems with ice maker
After 48 hours, machine only made a handful of ice cubes. Ice maker won't dispurse the cubes made
  • 489 Answers
Problem is with the icemaker.  Have the icemaker replaced.
Posted on Apr 27, 2008
Ice Box wont stay running
Hello Jeff;
My name is Peter. I am a retired field service refrigeration technician.
Ice Box? You must not be from the Glen Burnie, Maryland USA area.
Ice boxes or ice maker have several controlling factors. Some are repairable. Here is how they work:
1.) Your ice maker will harvest ice cubes 8 to 10 times within 24 hours.
2.) You have a control module in the front of your ice maker. This is like a small control board. It has a motor and plastic gearing system. It also control the lever system to fill your ice bucket.
3.) The control module tells the solenoid valve in the lower back right hand side of your unit to open and fill the ice cube tray.
Then you have a temperature sensor that tells the control the ice cubes are frozen.
4.) You either have a flex ice cube mold that will activate or a heater under the mold tat will turn on for a set period of time to release the ice cubes from the mold.
Send me the model number of your unit and then we can trouble shoot together.
Feb 13, 2015 | Refrigerators
Our ice maker fills but
Defrost the fridge leaving it unpugget 48 hours, this may solve the problem
Apr 21, 2008 | Refrigerators
Ice maker is not dropping ice
there are 2 things that could be problem, 1 is a heater element that heats the bottom of frozen cubes slightly to allow the cubes to be pushed out into the tray by plastic fingers under the cubes and controlled by a motor. best bet would be to get model number of fridge and/or ice maker and look for direct replacement online. There is a company out of Chicago that offers replacements for lots of models. Sorry I dont have their name, but google the results for ice maker for your make/model fridge.
Jan 28, 2013 | Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Ice maker does not consistently make ice...
try turning off ice maker for a day. remove the bucket that holds the ice. look all around bucket and into ice maker to determin if there is a jam, or if there is a cube stuck there preventing operation. Check that the ice arm can move freely and it is properly inserted on both ends. Make sure there is nothing in your freezer that could be getting in the way of the ice maker operation, either above or below the unit. One hint-wear disposable gloves when working with the ice maker-if you have any moisture on your hands, you tend to stick to the unit.
Jan 17, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker
sounds a liitle to fast actually, its rated for 8 cubes for "harvest"(cycle, and each cycle problably about 1:45, ittl take a while to fill the bucket , perahps 36-48 hours. once filled though maintains good normal use levels.
Oct 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
New GE profile Fridge Ice maker is very inefficiant for two people we have 3 drinks each and no ice
yea you ned to figure that the ice makler probalby makes 8 ice cubes every 2.5---3 hours. so if your filling a glass with ice, more then 8 cubes, the machines gonna take 3 hours to replace that!!!all machines regardlees of manufacture take a long time to produce ice
Apr 09, 2008 | Refrigerators
If the cubes are fusing together (such as when you overfill an ice tray), your solution could be as simple as adjusting the fill volume (there should be an adjustment under the front plastic cover, and the cover should just pop off and snap back on unless you see screws attaching it) and when your ice maker was replaced this probably wasn't calibrated correctly. Your mention of the side of the maker bulging also leads me to believe the water is overflowing and freezing within the dispenser (causing it to bulge and not dispense).
I hope this helps and Good luck.
Mar 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Jul 29, 2007 | Maytag MSD2756G Side by Side Refrigerator
LG LRSC-26922 Side by Side Refrigerator Logo
187 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
