Unless you unplug and replug the cooling temp switch
There is either a break in the cable, which when you push the plug back on you get connection, or the switch is gone. I would say there is a break/lose connection where the cable joins the plug that actually joins the switch. try this. Get a pair of pliers and crimp the joint tightly. If this doesn't work, cut the wire as close to the plug as you can, bare about 5mm of the end of the cable, slip it into the contact side of the plug and push onto the switch, then if it's still the same do the same with the other side. Bet it works! Go to a motor factors, get two new plugs to fit on the prongs, crimp the bared cable into the plugs and he-presto! A repair for $1.00
Replace the radiator fan switch,,renew your thermostat if needed,maybe your lower radiator is still running cold ,/poss,air lock in system,,
