Question about Kodak Easyshare Printer G600 Thermo Printer
Hi, I have a problem a paper is stucked in the printer
    President:
  • 1,996 Answers
Please go to this link to see a video with instructions for clearing a paper jam on your printer, and remove the paper from the rear slot if it doesn't eject automatically when you follow the instructions.
If you have further problems, here is the home support page for your model.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 23, 2009
Paper is stuck/jammed on the drum and I am having difficulty removing the d rum unit and toner
Hi lbestu,
Please Read Tip Carefully :-
Tip: To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance or repair
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For
Brother Printer Support
Feb 05, 2014 | Brother MFC-7340 All-In-One Laser Printer
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
Jan 05, 2012 | Epson Stylus C86 InkJet Printer
Paper jam but no paper in printer
Check the paper paths for any stuck papers.Gently remove any stuck papers.
Turn the printer off and on.Problem solved?
Unplug the printer and restart your PC.
Connect again, turn the printer on and print.
Hope this helps.Thanks!
Please rate this answer.
Oct 27, 2011 | Dell 1350cnw Laser Printer
Paper jammed when loading paper, don't know how to clear jam
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 24, 2011 | HP Photosmart 2610xi All-In-One InkJet...
I have paper stuck in it and can not get it out
Hi
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Jul 18, 2010 | Dell 1110 Laser Printer
I have a paper jam how do I get the paper out??
Hi,Turn off the printer. Open the printer door that allows you access to the ink cartridges and look for any stuck paper. Remove the stuck paper slowly. Turn the printer back on.
Jun 25, 2010 | Office Equipment & Supplies
Regular paper jams and printed images are not straight
hi,
follow these steps:-
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
mannu_rakesh
Aug 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
Paper jams
hi,
Thanks!
Aug 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
How do I clear a paper jam?
hi,
Thanks!
Aug 02, 2009 | HP DeskJet 932c InkJet Printer
Paper jams and the light comes on
hi,
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting the printer manufacturer for additional assistance and/or repair.
Jul 13, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Kodak Easyshare Printer G600 Thermo Printer Logo
96 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
