Question about Victory RIS-2D-S7-PT Stainless Steel
Compressor runs but not cooling
The pipe to the condensor is not cold but where the orfice is the pipe is hot is feon curculating
    Sergeant:
  • 202 Answers
I believe your compressor need freon
Posted on Jul 24, 2009
Why has my freezer stopped cooling ?
The freezer does not get cold the evaporator fan motor might have stopped working.
http://thesisreviewadvisor.com
Jan 08, 2015 | Refrigerators
Where is the a/c orfice and canaster located?
the A/C expansion valve (orfice) is right next to the evaporator
in fact that is what causes the Freon to change from liquid to gas.
and must be there.
the Canister, (the receiver /dryer ) is usually near the condensor. end .
you can see the line clear, open hood, see the 2 compressor lines
the 2 fire wall line(hoses/pipes)
see the 2 condensor lines.
the dryer is on the line to the condensor. just follow it, and bingo. thar she be....
Jul 02, 2014 | 2003 GMC Yukon XL
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
I have a 2004 Nissan Xterra. It is not cooling like it should. I changed the two filters behing the glove box. I checked the pressure and it is good. The compressor is coming on and sounds like the clutch...
When you say you checked the pressure did you connect gauges to the high and low sides to get both pressures, this sounds like it may be low. also what is the temp coming out of the vents. note on really hot days and humid the ac system doesnt cool as good unless the truck is moving down the road or highway and does take a while to cool down. at a stop or sitting or in traffic the ac temp will rise as the condensor needs to be cooled like the engine does, if its not cooling then the temp will not be cold, check the front of condensor for blockage, also make sure the fan is running with ac on. this fan should run when ac compressor is on,maybe clean condensor with water hose blowing from radiator outwardto front bumper, then make sure the hot/cold blend door is closing all the way,a quick test is to turn a/c on, turn temp control to hot and see if it gets hotter then back to cold and it should get colder. this sounds like the system may just be a little low. have an a/c tech check it, you may find its low or nothing is wrong. good day.
Aug 08, 2011 | 2004 Nissan XTerra
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
Air conditioning blows hot air when sitting still, cools somewhat when at highway speeds, but not cold. Has plenty of refrigerant, compressor is working.
You have a leak & not plenty of refrigerant
Why would it try to get cold when moving at higher
rpm?
Low Refrigerant
Leaks
Air in System
Dirty Evaporator
HVAC System Doors not switching
Expansion Valve or Orfice issues
Compressor Failing
Condensor dirty & filled with leaves between it &
radiator
& More
Jul 01, 2011 | 2004 Mercury Montery
Ac unit is not working properly just replaced the compressor the dryer and the orfice and it blows cold one minute and then the unit gets hot and dies the motor down.. What could be causing this? the unit...
I would make sure that the electric fan clutch is coming on. Sounds like the a/c compressor may be building up high head pressure and the fan clutch is not drawing air through the condensor to cool it down.
Sep 05, 2010 | 2003 GMC Envoy
Hey I am haveing a problem with My 2500HD ac system. I have changed The Condensor, evaporator, and the Compressor. I have charged it to the correct levels. It blows cool air, but it doesn't get cold....
Did you change the Receiver/ Drier and the Orfice Tube/ Expansion Valve? The Receiver/ Drier takes moisture out of the system and the Orfice Tube/ Expansion Valve controls the Hot/ Cold air. If that is bad it may not be opening or closing fully which would not let your A/C get as cool as it supposed to.
Jun 25, 2010 | 2005 GMC Sierra 2500HD 4WD
On my 2004 duo therm rv roof a/c,I turn it on and to listen to it, everything seems fine.But it`s not cooling properly.I have changed the filter,went on roof, removed cover,motor and fan are working...
on the compressor two pipes normaly one must be very cool .and other pipe very hot this means compressor is ok
if not cooling that much means low charge of freon need repair first the leak then recharge with freon.
Sep 17, 2009 | Heating & Cooling
I want to know about refrigerater but without compressor ,How it run ,Which technology use it
A refrig doesn't cool . It removes heat which is why the coils get hot . With the condensor mounted on the back of the fridge , air curculation dissipates the heat from the coils . Remember , this heat , is the heat being removed from the inside , by the refrigerant being pumped by the compressor . Some fridges , have a condensor fan to remove the heat from the bottom coils , and to keep the compressor cool . The thermostat , tells the compressor to cut off , when so much heat is removed from inside the ref . The property of refrigerants , is to attract heat , and since aluminum is a good conductor , the evaporator coils inside the freezer are made of aluminum . As the coils get colder , the fan inside the freezer , blows into the refrigerator , and returns to the freezer in a circular motion , thereby cooling the refrigerator . During defrost , wheather it be adaptive or mechanical , is to melt the frost accumulated on the aluminum freezer coils . If too much frost accumulation , the frost will act as an insulation , like the insulation on wire , then the ref. will not get cold .
Aug 28, 2009 | Kenmore 60721 Refrigerator
Victory RIS-2D-S7-PT Stainless Steel Logo
99 people viewed this question
Top Victory Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Victory Refrigerator Expert? Answer questions, earn points and help others
