Very week meaning that the picture is really dim - not as bright as it used to be? If this is so the Back Light Lamp Ballast or there are issues with the florescent tubes in the TV. Can be repaired if you wish to spend between $100 to 300 at a good service shop. Call around your area and get some estimates. A Good shop will give you them. Blessing, A/V Media Tech Guy
Was this helpful?
Yes
No
Popular Solutions for Polaroid FLM-2632 Television
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as...
(More)
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as well as a HDMI cable.
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then...
(More)
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then nothing and i havent had any picture since. its not my cable box because all other tvs work. i brought mine down stairs to try a dif. connection but still nothing. ive done the factory reset and uto search countless times but im at a dead end
TV is about 18 mos old and during last mos have noted a black line forming from top to bottom and...
(More)
TV is about 18 mos old and during last mos have noted a black line forming from top to bottom and the right side of TV almost like when you used to have to Degas you PC monitors Stays in same stop. it there as soon as unit is turned on Thanks for help
