Question about Amana ALW480DA Top Load Washer
How to change spin belt myself amana ALW480DAW help got belt do I need to flip machine over ? any tricks of the trade
How to change belt on maytag top loader washer?
Posted on Jul 29, 2009
I have an amana model alw480daw washer fills fine but wont agitate or spin and the tub seems to be really loose you can push it around from side to side way further than it should, any ideas???
From what you are saying the only thing that would really cause this is the lid switch, you can watch a video that explains how to repair this at the link below,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Amana Washing Machines
Replaced belt, new belt is burning when pump engages
hi i have the same washer and i can't figure out how to change the belt. please help. anthonylombardojr@hotmail.com
May 10, 2010 | Amana Washing Machines
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new one. Do you have a diagram I could view to help me install the new one?
I used the following links:
http://www.partselect.com/ModelFrames.aspx?ModelID=29693&ModelNum=ALW480DAW&mfgModelNum=PALW480DAW&ManufactureID=1&Selected=31971&Position=7&mfg=Maytag&Type=&Mark=7
http://www.applianceaid.com/amana-wash.html#belt
Oct 21, 2009 | Amana ALW480DA Top Load Washer
AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Apr 30, 2009 | Amana ALW480DA Top Load Washer
Washer Pump leaking.....
Please refer to my instruction here
Nov 14, 2008 | Amana ALW480DA Top Load Washer
Please Amana Washer agitates without water in but spins it out when water in
IF that's what is happening go to the pressure switch , the water level switch, give it a tap . this should solve the problem thanks the appliance doc. please rate my answer thanks.
Oct 09, 2008 | Washing Machines
Amana ALW480DAW Top Load Washer
sometimes the pump becomes stripped where the motor shaft goes into it.
Jan 22, 2008 | Amana ALW480DA Top Load Washer
ALW480DAW Washer Doesn't spin
had same problem grab agitator and rotate it clock wise and you should hear a clinging noise and try again to wash, it should be fine
cost free for now
Jan 20, 2008 | Amana ALW480DA Top Load Washer
Amana ALW480DAW washer
Remove the front panel by loosening the two screws that hold it in place. Unhook the spring that puts tension on the tension pulley. Remove old/worn belt and replace with new belt. Very important that you use the correct size belt or the motor may be damaged and remember to hook the spring back for the tension pulley. The new belt has to go around the inside of the tension pulley.
Oct 22, 2007 | Amana ALW480DA Top Load Washer
Amana ALW480DA Top Load Washer Logo
714 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
