Question about LG Vu CU920 Cellular Phone
THE PART THAT YOU HAVE TO CONNECT TO THE PHONE BROCK AND ALL ICAN SEE IS RED AND BLACK WIRES HOW DO I PUT IT BACK
  • 21 Answers
If you broke off the charger port and you see wires now, that's not something you can put back. Sorry. Sometimes you can hold the port to the wires to let it connect but be careful because you could fry yourself if you get shocked.
Posted on Jul 23, 2009
Alternator burned wire harness all wiresburned
Here is what the wiring diagram shows for 1996-2000
Feb 09, 2014 | 2000 Honda Odyssey
Pulled old switch out and had two black wires. New switch has 4 wires red,white,black , green
To wire this type of timer:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
Heres what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | Intermatic Inc. ST01C Digital In-Wall...
What does the black green and red wires mean
Wires are colored-coded to tell electrician how device works.
Green always goes to bare ground.
Black always goes to Black Hot from breaker.
Red goes to Load (light)
Switch you are replacing has 2 insulated wires.
These wires connect to black and red on new device.
It is possible to connect red and black in any order, turn power ON and see if device works.
If device does not work, then reverse red and black wires.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Jan 15, 2011 | GE 18024 Dimmer Rocker OnOff with Slide...
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
I am trying to replace a single pole switch with 2 screw connections both of which have a black wires. It controls an outside light. There are 2 white wires are capped together. The smart digital timer has...
Here is how to wire that timer:
1) Timer green wire connects to bare ground wire.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This will power timer electronics.
5) Turn on electricity, and push ON-OFF button located in each corner. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Hardware & Accessories
I have a ground and white wires and a black wire... which do I hook to what... can I put green ground, and black with black, but can't i put my red and white on the white? For 7-Day Digital in-wall timer...
Utilitec 7-day timer will only replace single-pole switch.
Single pole switch has two brass screws and a ground screw.
Links below show wiring for both Utilitec 7-day timers
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
If this is not your timer, then add a comment and specifically state which timer you have and which wires came off which screw on old switch.
The best way to start is to identify exactly which wires came off old switch.
How to wire
If the free answer is not right for you, then take advantage of fixya phone service.
Expert helps you via phone for a price.
Dec 30, 2010 | Garden
HOW DO I CONNECT TO POWER SUPPLY? WHERE DO THE WIRES GO?
You posted under Intermatic EI210 countdown timer.
To confirm this is your product, open link below:
http://www.amazon.com/Intermatic-EI210-Electronic-Countdown-Minutes/dp/B001EE1J74
Manual with operation instructions appear on link below
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei220w%20-%20english.ashx
EI210 replaces single-pole switch only.
Single pole switch is where 1 switch controls the Load (light, fan, motor)
To wire this timer:
1) Single-pole switch has 2 insulated wires and 1 bare ground wire.
2) Connect insulated switch wires to timer red wire and timer black wire, in either order for now.
3) Connect timer green wire to bare ground wire.
4) In back of electric box are white wire that are twisted together and covered with wire nut. Connect timer white wire to these wires. This will power electronics located inside the timer.
5) If electric box does not have white wires described above, then connect timer white wire to bare ground wire along with green wire.
6) Turn power ON. Press oval button. If indicator light turns ON, then timer is wired correctly. If indicator light does not come on, then reverse timer black wire and timer red wire.
http://waterheatertimer.org/How-to-put-on-wire-nut.html
Add a comment if you need more free help.
For a price, fixya expert gives you same instructions shown above via phone while you connect the device.
Dec 30, 2010 | Intermatic EI210 Electronic Auto Shutoff...
When I press the timer to go on my three outdoor lights go on and off, timer clicks that way too
Timer is wired incorrectly.
1) If you have battery-operated Intermatic EJ500 or ST01C, with red, blue, black and green wires:
Then red wire is where blue wire should go. Swap blue and red wire.
2) If you have Aube battery-operated timer, add a comment and say if you are replacing single-pole or 3-way switch. And say where each wire is so far.
3) If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
Heres how to wire timer
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
Dec 11, 2010 | Woods Hardware & Accessories
How can I change the electrical connection? It has four wires. One white, one black, one green and one red. Where do I connect them?
On the back of the dryer where the plug wires in you'll see 3 screws. The white and green wires go together in the middle. look at the left and right screws and you'll see wires connecting to them from inside the dryer. just match the wires, put the black on the black and the red on the red.
Oct 31, 2010 | Whirlpool LER4634J Electric Dryer
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
LG Vu CU920 Cellular Phone Logo
26 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
