Question about Sewing Machines
I have a Pfaff Tiptronic 1171. After I have put thread on the bobbin using a Pfaff type bobbinand making sure the pin on the bobbin threader is in the hole on the bobbin, and inserted it into the bobbin case and threaded it through correctly, the thread won't feed through the bobbin case. It only comes out if you yank on it hard,which I tried after having adjusted the tension screw in both directions. I've tried this with several different threaded bobbins and have the same problem. If I insert the bobbin into the machine and try to sew with it, the thread breaks or it doesn't sew the material together.
  • dani219 Jul 23, 2009
    Thank you! You're explanation makes sense. I'll get it serviced.
  • 520 Answers
The tensioner itself has gone out of adjustment beyond the screw adjustment capabilities. The tensioner will need to be serviced to insure it is correct. While they have it have them do a full service on the machine. They usually adjust all of the tensions and settings when they do maintainance. This way you do not get charged double. Hope this helps. Please re-post with updates or questions. If you feel that the solution has helped then please accept and rate. Thanks cj2176. sorry for the mis-spelled words. My spell check is on the fritz. Thanks again.
Posted on Jul 23, 2009
Blanket stitch on Pfaff 1171
You need to check your owner's manual. Most machines of similar age do not have the blanket stitch.
Looking at Pfaff 1229 sewing discussion topic PatternReview com
(see comment)
Pfaff 1171 Tiptronic Sewing Machine
Aug 09, 2017 | PfaFF Sewing Machines
I have a pfaff 2040 and when the needle goes down to pick up the bobbin thread the main thread wraps around the bobbin housing and jams. Doesnt grab the bobbin thread. How can I fix this?
Be sure to use a brand new needle because a bent needle could miss the bobbin thread.
Search the internet for sites and videos relating to sewing machine timing or take it for service.
Dec 02, 2016 | PfaFF Tiptronic 2040
Help trouble-shoot jammed machine
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | PfaFF Tiptronic 2030
Pfaff tiptronic 2020 locking up/cutting bobbin thread
try changing the needle
when sewing a project-- the needle & fabric & thread must be compatable
check to see if there is any burrs on the needle plate or on the bobbin case
always make sure every thread guide is used
make sure the bobbin is inserted correctly in the bobbin case
Mar 31, 2012 | Sewing Machines
How do i fix the tension on my pfaff tiptronic 2020
It sounds like you need to adjust the bobbin tension. There is a small screw on the bobbin case to tighten/loosen the thread's tension coming out of the case. Refer to the user manual on the procedure to set it.
Nov 28, 2011 | PfaFF Tiptronic 2040
My Pfaf 1222 made a rattling noise, but was sewing. Now it jams with thread after two revolutions, need to hand turn the wheel to get it to turn those 2 turns. I broke one needle. I bent another. When I...
Check the manual for maintenance infromation.
Noise can be from lint in the bobbin area.
After cleaning, re-thread the machine with the presser foot up to see the combination of cleaning and "presser foot up" threading helps.
Mar 29, 2010 | PfaFF Tiptronic 2030
The threaded needle will not pick up the bobbin thread. It seemed to be in perfect shape when last I used the machine, a Pfaff Tiptronic, but now, suddenly, it will now work. The threading of the bobbin...
Hi, here is a few suggestion...........
A few suggestions:
  1. Re-thread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Take care
Feb 21, 2010 | PfaFF Sewing Machines
I have lost my manual and can't remember how to thread the Tiptronic 2040
Make sure you have your spool of thread pushed all the way back on the spool pin with the proper size thread cap. Make sure your foot is in the up position, as this opens the tension discs. There is a small metal circle on top. Pull the thread behind it and under it and directly down. Come back up the other side and around the take-up lever. If you cannot see the take-up lever, move your handwheel until it is all the way up. After you have threaded it around the take-up lever, it comes back down this same side. On either side of your needle bar are two small metal clips. It doesn't matter which side you put the thread into. To put it into the clip, hold the thread taunt and pull it from the outside in against the clip. Now put your foot in the down position. When you pull the thread, it should be tight. Push your needle threader all of the way down. It has a tiny (extremely tiny) hook that will come through the eye of the needle. Wrap the thread around the metal bar/hook on it and gently bring it in front of the needle but under the metal guides that are in front of the needle eye. This next part takes some coordination, gently realease the thread as you simultaneously release the threader. It should pull a loop of thread through the back of the needle.
Also, when you wind a bobbin, you must thread it through the top of the metal disc on top and not underneath it. This provides the correct amount of tension for bobbin winding.
If you are not sure if you have threaded correctly, with the foot in the up position, pull on your thread. It will pull freely off the bobbin. With the foot down you should have a lot of resistance. Good luck to you!
Sep 11, 2009 | PfaFF Tiptronic 2040
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
