Question about Dryers
Kenmore,softheat will run but wont dry - Dryers
    Sergeant:
    Novelist:
  • 197 Answers
You don't state if it's only got one heat setting? If it is running on the lower setting, which is more likely, or no heat at all then the element is broken. There are many types of element, the box element, wire surround element and direct heat. The box and direct heat are easy to replace, but the element is a pig! For a quick look, take the top of your machine and if you see an element like on an electric fire, it's a pay someone else job! Check out the prices of 2nd hand dryers!!!!!!
Posted on Jul 23, 2009
    President:
  • 1,776 Answers
If the dryer is not heating or not heating at a high enough level, it may be caused by a faulty thermal fuse or a heating element that is burned or partially burned out. Both components can easily be tested with an ohm meter or multimeter for continuity. If there is no continuity, then the component is defective. The thermal fuse is usually located on or near the exhaust duct just inside the back the dryer. The heating element will be obvious when you see it. Sure hope this helps ya and best wishes.
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
Apr 20, 2010 | Kenmore 72802 Gas Dryer
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
What is the order of the green,red,white and
Red goes with the red, usually right side. Black on left white in center and green attached to metal on frame.
Oct 23, 2009 | Dryers
It wont stop running... dries perfectly but wont stop. Thanks! ;o)
either a timer or the heating element or a blocked vent also there is a resister on some kenmore/whirlpool dryers and if it is out it wont advance in the auto cycles. It should advance in the timed cycle with or without heat
May 11, 2009 | Dryers
Kenmore washer wont fill up during rinse
The Timer is the most common problem. Call Sears or Appliance Parts stores for new timer and replace it
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Dishwarsher
This worked great - press Sani Dry, then press Heated Dry - then repeat - press Sani Dry, then press Heated Dry. All control lights will light and then press Cancel. The control panel should work normally.
Nov 05, 2008 | Kenmore 24 in. 17033 Built-in Dishwasher
Dryers Logo
52 people viewed this question
Top Dryers Experts
