Question about Canon imageRUNNER 5000 Copier
Network Printing is not working
I can ping the device, scan from the network, get to it from the network via http but I cannot print to it. I created a local TCP port using RAW and even LPR and still have problems printing to it. Any ideas?
  • 11 Answers
What drivers are you using? try both PCL and UFRII. also, check thru WWW interface(will be faster) if there's a department managment turned on. i it is, disable it. i assume you are creating local tcp/ip port with printer ip, raw mode, port 9100 and device is canon network printer. also did you noticed is windows discovers the device as canon network printer, raw mode etc, or you have to enter it manually? if it can't discover it, there's some connection problem.
Posted on Jul 24, 2009
Network Printing (LAN)
Sir/Mam,
Did you give the machine a static IP address or DHCP meaning let the network decide what IP address is issued this machine LOVE static YOU telling it via admin setting on the copier, admin, admin 1, network, basic . set ip, mask etc.
Mar 26, 2014 | Konica Minolta Bizhub 600 750 Image...
Linux driver
Printing via USB:
  1. Get the samsungmfp- repository.
  2. Install samsungmfp-driver (samsungmfp-data will be installed automatically as a dependency).
  3. Go to Administration > Printing and delete previously created printer device(s).
  4. Connect printer via USB.
  5. Once new device has been created, go to Properties and change the Make and Model to Samsung SCX 4521F All-In-One.
For wireless printing:
  1. Connect to your printer. To get the IP address of your printer:
    1. Hold down on the printer power button for about 5 seconds; light will start to flash and when it begins to flash even faster let it go. This will print out the Configuration and Network Report.
    2. Locate the IP address on the Network Report and type it into your web browser.
  2. Once you are in the SyncThru Web Service, go to Network Settings and than to Wireless.
  3. Configure your Wireless Setting through the Wizard and follow the setup process (note that if your SSID contains space your network will not be displayed).
  4. Once the printer is connected to your LAN go to printer setting (Administration > Printing; Properties).
  5. Click the Change button for the Device URI.
  6. Go to Network Printer > Find Network Printer and type in the IP address of your printer.
  7. Apply the settings when it find the PASSTHRU. Device URI should looks something like this: lpd://[IP Address]/PASSTHRU.
Nov 04, 2013 | Samsung SCX 4521F All-In-One Laser Printer
Sharp MX-2300N Color scanner can't find network
Drivers are for print functions only (or twain scan via USB). Check for bad cable, port, or jack. Could be another device on the network is being handed the IP of the copier via dhcp (or vice versa) can you ping it from a workstation? I have also seen the dell network assistant utilities on some dell workstations cause issues like this.
Jan 11, 2013 | Sharp MX-2300N Color Copier
I have Muratec 2010mfx, It stop printing but still I could scan and use copier portion, its hooked up with our local area network and our network is up. Thanks for all your support in advance.
Contact the people that set it up for you...sounds like IP address may have changed ...the machine requires a static ip address...see if you can ping the machine.
Jun 11, 2011 | Muratec Copier
How to connect the machine to the computer for printing
Be sure that you have network option installed. On top cover of the printer itself (under the scanner) you can see a floppy drive, can you? OK, then it is capable of network printing. Also parallel (Mini-Centronics) port will work.
You may try parallel printing first, it is easier. Download from
www.xerox.com/support drivers for your DC440ST.
Install driver. Connect parallel port to computer via Cenntronics cable and you'll be ready.
If you want to print from network you must have UNIX printing installed in Windows. You have to create a new port in the printer driver and create a print queue and name it "lp". Port address is also needed. For example 192.168.0.1.
To set up network address on the printer you have to log into the printer as administrator.
Press (key) button on the top right part of the keyboard.
On the touch screen enter: #22222 (hash sign and five 5's)
Enter "Networks settings" "TCP/IP" "network address" "STATIC" "192.168.0.!" for example" "SAVE" "QUIT" and the printer will boot.
You may have to ping for the network address to see if it responds. If the copier/printer prints out a config sheet in five minutes you can check the address and other setting you just did.
If the printer DOES NOT PRINT the config sheet it may be disabled in settings. You can log in again (key) #22222 and enable "print config sheet" + reboot again.
Sep 08, 2010 | Xerox DC440ST Copier
I want to print copies from my workstation how to i connect this to canon ir3300
For that it should have a network adaptor, if that is availabe just feed an ip-address in machines, and connect with your workstation and installed the driver of printer.
Jul 09, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
No network printing
you need to add orinter to printers and faxes folder via IP address if you can contact me via phone i can walk you through it
May 11, 2009 | Canon imageRUNNER 3035 Black and White...
Printing problem
First, try to do a test print on the printer. This helps to determine the status of the printer and narrow down the problem. If it does print then change the network cable and/or the port where it is attached to the wireless router. Good luck
Apr 27, 2009 | Office Equipment & Supplies
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Konica Minolta Di1610 can't print
hello
is it conect via net or parall port?
have you try to detect the printer by its ip ?
(ping)
pini
Feb 14, 2008 | Konica Minolta Di1610 Copier
Canon imageRUNNER 5000 Copier Logo
332 people viewed this question
old marine
old marine
