Question about HP LaserJet 4600dn Color Printer
Just stop printing
Ran a sensor test and got these codes A-0 B-1 C-0 D-0 E-0 F-1 G-1 H-1
Lights come and whenyou light the lid it trys to config itself but at first it stop at initializing. turned it off then back on, then it stopped at config. Now we have it starting to the main screen so i ran a test and all was good except the sensor test. I printed out a configuration page and got some numbers in the lower right. It's connected to the lan line
  • 51 Answers
Turn off power, remove the JetDirect Network card if present. turn back on and see if it gets to READY state. If yes, you have a bad JetDirect card.
If still having problems, might be a formatter issue/engine board or other factor, need more info for better diagnosis.
Thank you
Posted on Feb 11, 2010
Rough idle
upstreams control the fuel mixture. i would put a scanner on it that can see the voltages fluctuate to see which one is actually your problem. dont just throw parts at it.
May 24, 2017 | 2002 Chrysler Sebring
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Output speed sensor
My wife's last car did that when the input speed sensor conked out. so mabey replacing your bad sensor will help.
Jun 02, 2013 | 2008 Ford Taurus X
Model Gw709AU
Feb 20, 2013 | Fisher and Paykel Washing Machines
I have a ford v6 3.0 dohc i changed plugs and wires fuel filter and fuel line pressure sensor had five codes come up the car starts properly took for a test drive and ran well but shut off when i stop
Code 191 is fuel pressure range-performance.
Code 172 and 175 are O2 sensors reading rich.
Codes 1132 and 1152 are O2 sensors not switching.
Under normal conditions, the fuel pressure should be around 40psi.
The pressure sensor is reading the pressure is too low or too high.
The O2 sensors should be switching back and forth between lean and rich. They are both staying rich.
Based on that info, I would reason the fuel pressure regulator has failed, or the return line to the tank is plugged.
The engine is getting too much fuel and the computer can't control it.
Jul 20, 2012 | Ford Taurus Cars & Trucks
95 mazda 626 flashing o/d off and no speedometer
These guys are breaking parts every time you go there. Would never have replaced the ecu. It was the crank sensor to begin with. Replace the vss yourself. It is easy.
Jul 18, 2017 | Cars & Trucks
1992 f250 occasionaly surges and dies when i stop at lights
there is a pressure feed back sensor going bad all the times
also check the two hoses connected to this sensor for crack or blockage
check the pipe that goes to the egr valve for crack
it won't hurt to pull the egr valve back out to check to see if there is any thing cause the valve to stay open
Mar 07, 2010 | 1992 Ford F250
Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
HP LaserJet 4600dn Color Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
