Car buying made easy Costco members receive low prearranged pricing on new and certified pre owned vehicles at participating dealerships nationwide Locate dealership today
Because some people think they are superior to others. That is why the Declaration of Independence is so important. It declares that all humans are equal and they deserve liberty. After the revolutionary war, the slave owners would not join the union if they had to give up slavery. The issue was delayed for years. Eventually a civil was under way because of slavery and other issues. Abraham Lincoln and the Republican party used this opportunity to end slavery. America had slaves but it did not start slavery! America ended it!
The main difference in the series is the dropping of the Australian-made V8 engine, which has been replaced by an American-built Generation III 5.7-litre alloy V8. The American-built engine has more power and torque.
George Washington had a member of congress boycott his swearing in, not Lincoln. The name of the congressman was John Lewis. If they had a moroon like Trump then they all would have walked away.
Well its a american muscle car and no doubt the bushes are worn somewhere,its the drivers fault as a muscle car can only do straight lines ,and not bends like a europeon sports car and it looks like someone has tried to do the dreaded bends with a american car causing the bushes to wear out .boy do i love winding up you americans about this -----till i watched top gear last week and hey a new stingray out with rear wheel drive only but all new suspension in carbon fibre on a race track against a porsche with 4x4 and guess what the stingray won ,no sliding or anything in fact it was the porsche that was slipping .and its its 20.000 GBP cheaper than anything else near it mainly the F type jag ,but then your talking different class with a JAGUAR ,i know i have one
The most common cause is a worn out three way main catalyst. This is a common fault code on Nissan, it seems they use cheaper catalytic converters than American cars.
This cable should not get hot. There are two main causes. I assume it is only hot at one end - the battery end.
1) The battery connection is loose so it is making a poor connection = heat
2) The crimped connecter on the battery lead is failing. In this case you would replace the lead.
if you by passed the relay and clutch engaged then this shows that pump works ??but was it getting cold on and around the restrictor valve where the pipes enter the cab is normally a valve block but american monsters use a valve in the pipe for cooling and if its not getting cold their or blowing cold inside cab then system needs re-gassing with R 134 gas if its an older system with R 12 gas then it will need to have adaptors fitted to valve connections and refilled with R134 gas.The main cause of A/C system loosing gas is porosity in the rubber flexible pipes also the back seal on the pump.Or just regass and put a leak stopper in the system
