Question about IBM ThinkPad R51 Notebook
IBM R51 Backlight Problem..
I have opened this computer (R51) case for changing WLAN card. So that one of the antenna has been touched to mainboard and backlight has gone away.
I had some suspects about having inverter damaged. To check that, I have changed complete screen part with the one I have (IBM R52)..Result was the same. After complete screen change Everything was dark. I can see the pictures on the LCD but no back light.
Later on, I have tested complete screen of R51 on my R52 system..So everything was OK. Backlight was there..
I understood that there is no problem with LCD Screen part of the system.
Is there a way to feed inverter from somewhere else..
Kindlym Regards
Celalettin
  • cdizman Jul 23, 2009
    Actually, I have replaced complete screen with the working one. So Inverter is normally in the LCD Panel Part of the Notebook. I have changed complete LCD Panel with cover and all parts in it.
    I think I blowed something on mainboard. External monitor is working perfectly. And this LCD Panel part of the notebook working on my R52.
    Is there a way to supply power to the backlight from somewhere else ??..
    Novelist:
  • 117 Answers
Check the model/part on the inverter. if you know you have a good one on the second laptop, remove it and try it in the non-working one. if the parts match which most of the time they do, then you are ok, it should only be two wires on the inverter, one coming from mobo, one coming from lcd. if that doesnt work you have blown a capacitor/resistor somewhere down the line. in that case it will have to be serviced and will run you anywhere from 80-130 if you find a place local or on ebay.
Good Luck!
Ruben
Posted on Jul 23, 2009
How do you take out T42 IBM broken power jack in order to put in a new one
you need to remove the keyboard then the upper casing... if you have a modem, remove it to get more work room. you should be able to unplug the power connector off the mainboard (the wire between the power jack and the mainboard) and snap the old jack out of place. be careful not to break the board or anything while doing so, though it should not be hard to remove the jack since it is not soldered. best of luck
Jan 25, 2011 | IBM Laptop DC Power Jack for Thinkpad T40,...
I have an ibm R51 and the radio is off and it keeps telling me to turn it on to use wireless but never works.
Look for the wireless on/off switch of the wireless adapter. Usually it is located infront of the computer right beside the LED indicators. Make sure that the switch is in ON position. If not infront, look on the side. You can also enable/disable the wireless network card by pressing Fn + F5.
May 19, 2010 | IBM ThinkPad R51 Notebook
IBM Thinkpad R51-USB not working
get a PCMCIA USB port, I have one with 2 ports, I have seen them with as many as 4, and I found mine on ebay, though most electronics stores would have them, you can also get them with firewire ports, too
Sep 23, 2009 | IBM ThinkPad R51 Notebook
How to turn on my wireless internet on my think pad g41 ibm
Hi I found an article on this link:
http://www-307.ibm.com/pc/support/site.wss/MIGR-70480.html
This package provides the Wireless LAN (WLAN) driver and UtilitySoftware for Microsoft Windows XP and Microsoft Windows 2000 to enablethe following adapters:
- IBM 11b/g WLAN Mini PCI adapter
- IBM 11a/b/g WLAN Mini PCI Adapter II
- ThinkPad 11b/g, 11a/b/g, 11b/g/n, 11a/b/g/n WLAN Mini PCI Express Adapter
- ThinkPad 11b/g WLAN Mini PCI Express Adapter II
- ThinkPad 11b/g WLAN Mini PCI Express Adapter III
The following systems are supported:
- G41
- R50, R50e, R50p, R51, R51e, R52
- R60, R60e, R61, R61e, R61i
- R400, R500
- SL300, SL400, SL500
- T42, T42p, T43, T43p
- T400, T500
- T60, T60p, T61, T61p
- W500, W700, W700ds
- X32, X40, X41, X41 Tablet
- X60, X60s, X60 Tablet, X61, X61s, X61 Tablet
- X200, X200s, X200 Tablet
- Z60m, Z60t, Z61e, Z61m, Z61p, Z61t
Hope this helps.
Jun 25, 2009 | IBM ThinkPad G41 Notebook
R51 Thinkpad Monitor Problems
To answer your question Morgan, yes you can get a new LCD display for your laptop! Typically people sell the entire assembly which is the screen, backlight, display cable. It then fits into the thin plastic casing around your current screen. They are actually pretty easy to replace the problem is you oftentimes have to remove the computers keyboard, and other pieces of plastic on the top that might be in the way. Also there are usually anchoring screws on the bottom that have to be removed as well. There should be one little teeny tiny cable you have to pull out that connects to the mainboard, and then reconnect with the new display. Try this website if you want to order a new one their price is only $120 (which is great for a new LCD screen).
http://www.blisscomputers.net/servlet/the-44892/IBM-R51-THINKPAD-LAPTOP/Detail
Feb 21, 2009 | IBM ThinkPad R51 Notebook
Disable boot up password in R51
You could open up the R51 and remove the CMOS battery. This would reset the password.
Here is a link I found that allows one to hack the BIOS password:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Or try this fixya thread:
http://www.fixya.com/support/t1641914-ibm_thinkpad_r51
Feb 06, 2009 | IBM ThinkPad R51 Notebook
R51 will only start on battery.
Well it sound pretty much like power is not reaching the laptop components so neither the computer turns nor charges the battery using the power adaptor. You mention that you used the power adaptor from other laptop (hopefully same model he he) so it is clear that the fault is not it.
It might be the power "inlet" , I mean the socket where the plug is inserted, it can always get broken.
Another theory is that it might be the power regulation circuit on the mainboard.
In both cases it requieres to send the laptop to be repaired.
A home made "solution" might be to dissassemble your laptop and test the power on the mainboard using a Voltmetter, this requieres some skils so if you decide to try it be cautionous.
Good luck!!
Jan 14, 2009 | IBM ThinkPad R51 Notebook
IBM R51 Laptop cannot be turned on anymore
does your hard drive have a "caddy" or "drive sled" installed? Mine did the same until I bought one.
Dec 19, 2008 | IBM ThinkPad R51 Notebook
IBM thinkpad R51 pink screen
You will need to replace the cold cathode tube that backlights the display.
Go Here: http://www.pchub.com/uph/ for a replacement screen.
Feb 18, 2008 | Lenovo ThinkPad R51
IBM ThinkPad R51 Notebook Logo
1,223 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
