Salve La stampante Photosmart HP D5160 dopo l'accensione inizia a produrre rumori come ingranaggi che si graffiano ripetutamente nell'area vicino al cassetto di sostituzione delle cartucce, alla fine dopo alcuni istanti la stampante smette di fare rumore ed ? pronta per la stampa, ma ultimamente, dopo sopra, sistematicamente non viene pi? stampato e il punto esclamativo rosso lampeggiante rimane. Le cartucce sono originali e hanno una capacit? superiore ai 3/4. Spero in tuo aiuto il prima possibile. Grazie. Roberta
SOURCE: photosmart d5160 keeps printing a test page after
Please perform the following steps:
* Make sure the CD/DVD tray is closed.
* Double-click the HP Solution Center icon.
* In the HP Solution Center (for Windows OS, if you are using Mac please let me know), click the tab for the HP Photosmart 5100 series.
* Click the Settings button.
* Point to Print Settings.
* Highlight and click Printer Toolbox.
* After the Printer Toolbox opens, click the Align print cartridges button.
* Follow the on-screen prompts to align the cartridges and print an alignment page.
:) Dr Tony
SOURCE: I have an HP Photosmart
I have an HP Photosmart D5160 ALways displaying Error and Red light blindking..
SOURCE: prin queue problem
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
SOURCE: problem of my printer photosmart d5160
I have the exact same printer. Struggled for hours with it, until I learned it's ways. If you have good cartridges in and purge your print buffer from your computer, then 'gently but firmly' slam the top cover.
I don't see sensors, etc that detect it being up, but I just closed mine, had ! blinking, etc. Then gently 'slammed' the top cover and it reset and worked great.
SOURCE: Hi How do i clean the print heads? on
Hi there not to shure so put file for you.
Hi there
I have put a manual as well for you.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/HP-Photosmart-D5145-D5155-D5160-Manual.pdf
You will need an adobe reader to see this file if you not got a Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website is only there
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
or:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
