SOURCE: Flashing red light won't correct on HP Photosmart D5160 printer
Here is a HP document that explains what the blinking lights mean and how to fix it:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01041365&dlc=en&product=1155996
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: HP photosmart C 5283:message on blue display 83C00020
Your scanner unit has failed. Uneconomical to get repaired.
SOURCE: problem of my printer photosmart d5160
I have the exact same printer. Struggled for hours with it, until I learned it's ways. If you have good cartridges in and purge your print buffer from your computer, then 'gently but firmly' slam the top cover.
I don't see sensors, etc that detect it being up, but I just closed mine, had ! blinking, etc. Then gently 'slammed' the top cover and it reset and worked great.
SOURCE: Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end.
Figure 1: Power cord
The product uses a power module, if the power supply is a power cord connected to a power module.
Figure 2: Power module
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product.
Figure 4: Power cord
Step four: Service the Product
If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
or:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
