Question about Toys
The engine and track has been sitting for about 5 months. They both have gotten dusty and now the engine won't run.
  • 850 Answers
Dirty contacts clean contacts & track joins
Posted on Jul 23, 2009
It has been sitting or 3 months and won't start and it is a kick start Suzuki 4 wheeler and it was running great 3 months ago but this cold whether I think is what the problem is .
Hi erik
My first point of call would be to clean the spark plug, it could have gotten corroded while the bike has been standing. Hope this helps.
Feb 20, 2013 | Motorsports
97cc baja doodle bug won't start
Assuming that the engine can be turned over with the starter, the most likely culprit is it's not getting enough fuel, especially if it's been sitting for 6 months or more. AT YOUR OWN RISK, remove the air duct after the air cleaner and pour a shot-glass full OR LESS of gas directly into the carburetor or throttle body. It should start and at least run briefly. If it does, then add at least 3-5 gallons to the fuel tank. If you've run out of gas, then adding just one gallon is not enough. Today's fuel-injection systems have pressurized fuel lines which need at least a gallon just to fill all the pumps and filters between the tank and the engine. Good Luck, TechJoel
Nov 04, 2012 | Cars & Trucks
My 1988 Jeep won't start when I crank over the engine. It will turn the motor over a few times then I lose battery power. With a cold start it sometimes will start on first attempt but it has gott
it sounds like the starter is bad but first run a pair of jumper cables from the battery to the starter and the other jumper on the ground side just to make sure you don't have a bad cable larger parts stores can test it off the car if you bring it to them
Aug 31, 2012 | Cars & Trucks
Tracking issues with SONY XAV60
If you smoke or it is dusty in the car, cleaning the laser lens may help. At any rate, if you are careful, cleaning the lens won't harm anything.
Feb 24, 2012 | Sony XAV-60 Car Video Player
Car won't stay running after sits overnight and runs good after you do get it started
In the morning, turn key to on position for 5 seconds. Do not crank.Then turn off for 5 seconds. Repeat this about 5 times. Then try to start. If engine starts right up, the fuel pump check valve is bad. Meaning all fuel in fuel line is returning to the tank when car sits overnight. The only fix is to replace fuel pump. If that doesn't work, replace coolant temp. sensor for the computer. About a 12.00 part.
Feb 05, 2012 | 1994 Pontiac Grand Prix
After running out of gas,with 5 gallons gas put in tank, now cant get fuel to engine.
Possibly clogged fuel filter or fuel pump. With running out of gas the crud that sits on the bottom of the tank may have gotten picked up and push to the filter. Also the gasoline is what cools the pump and with no gas it may have over heated and will need to be replaced. Hope that helps.
Mar 05, 2010 | 1997 Chevrolet Cavalier
When i turn my 360 on it doesn't read the disk
Could just be the laser is dirty, 9/10 in this type of case the laser just needs a clean to get everything back up and running normal again.
But also it can be the tracks of the drive not sliding back all the way, meaning the disk is not sitting in the exact correct placement, this usually being more of a problem in the homes of smokers, due to the dust in smokers homes being thicker and sticky and not dry like normal. This is fixed by opening the drive and cleaning the left and right tracks.
Another problem could be the face of the disk spin plate being dirty/dusty so not gripping the disk fully so not getting full speed to read and can also be cleaned. Finally if your drive has a drive belt the belt may have gotten dirty so needing cleaned or may have also lost its shape (common on Samsung drives), placing the belt in boiling water for a minute or two fixes this.
Hope this helps
Jan 01, 2010 | Microsoft Xbox 360 Console
Toys Logo
70 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
