Question about Video Game Consoles & Games
PS2 Action Replay MAX: PS2 can't read saves off a USB flash drive
Yes I do have the MaxDrive software installed on my PC, and I'm able to use this to transfer game saves (*.max format) from my hard drive (which were downloaded from gamefaqs.com) onto a flash drive. Now while I was running the AR software on my PS2, I was making an attempt to transfer the saves from the flash drive to the PS2 memory card. But even though AR did detect the flash drive, there were no saves listed as if somehow it did not properly read the flash drive. Now I've tried doing this same procedure on 2 different flash drives, but both came out with the same failed result. The MaxDrive software program on the PC did read the saves, but the AR on the PS2 didn't read anything at all. I don't understand this at all. Maybe I should use AR's own flash, the MAX Drive USB to transfer saves, but many say that any flash can be used for this. Well other than this, I don''t know what else to do other than getting the MAX Drive. But getting the MAX Drive does cost money, and I do not wish to spend more money just for this purpose, especially when chances are that this could fail too, and I ended up with money wasted. Does anybody have suggestions on resolving this?
  • fredbeer Aug 06, 2009
    I'm sorry tikktokk23. I did exactly as it says, but when I reached step 8, "delete partition" has been "greyed out" and I cannot activate/click on it. Should I try something else?
Here are some instructions I came across when trying to find out how a regular usb drive could be used with AR. I don't want to purchase the MAX Drive either.
Hope this helps, I haven't been able to test this yet for myself.
"you can use ANY size, brand, and style of USB flash drive (I'm using my mp3 usb drive) as long as
1. it's plug and play and
2. you follow these semi-simple steps to format your flash drive so that your ps2 will see it.
1 insert drive onto computer
2 click on start/settings/control panel
3 go to administrative tools
4 double click on computer management
5 click on storage/disk management(local)
6 find your flash drive (BE ABSOLUTELY CERTAIN THAT IT'S YOUR FLASH DRIVE)
7 right click on the area that says your flash drive's name AND has a blue stripe above it
*8 delete partition ((it will tell you that you'll lose all of your data stored on the drive)(hence why i said to make absolutely certain that the drive you're clicking on is in fact your usb flash drive)
9 right click on the now unallocated space where your drive was before
10 create new partition: in the popup it will give you some options; volume label, file system, allocation unit size, perform a quick format
11 volume label doesn't matter, file system has to be fat, allocation unit size has to be 16k, and you choose weather to quick format or not (I did just so you know)
12 after it's done just plug it into your ps2 usb port and away you go!!!!"
* - You may not have to delete the partition manually--I didn't. I just went right to the 'format' option when I right clicked on the area with the blue strip. All you really are trying to do is format your flash drive to FAT file system and allocation unit size of 16k. That's it!
I hope these instructions help someone out there. You DON'T have to buy the Action Replay flash drive in order to transfer files...your flash drive will work, but you have to be willing to reformat it to FAT (which WILL erase all of the files on it, so move them or back them up first BEFORE you click 'format')
Posted on Aug 06, 2009
Be sure that the flash drive you are using is at or less than 2 gb in space
All you want to do is to format the usb drive in FAT file structure and 16k unit allocation size.
When i tried those instructions with a 4gb flash drive it would not work (no matter what i did). But when i turned around and used a 256 mb flash drive it wotrked without a hitch.
Posted on Aug 19, 2009
2 Suggested Answers
SOURCE: guys my ar code manager says it cannot work
my answer is that action replays do that they **** i hate them they mess up all the time
Posted on Jul 28, 2009
PlayStation 2 Action Replay Not Working
the arrow does not appear on the screen why?
Feb 16, 2014 | Datel Action Replay Max PS2
My action replay makes my controller not work ps2
you might want to double check your master code for the game, and check the version of your software too i had the same issue i was using the wrong master code
Oct 29, 2009 | Datel Action Replay MAX for PlayStation 2
What software can i use to play files from my flash drive using a ps2? Can i use Action replay or codebreaker or any other software?
well i would have to say that playing a game from a usb drive is not dependable, think about this for a second. The playstation 2 would have to somehow read the files on the usb drive, but then also take information off the drive to run the game. that usb port wont handle that much data, its just not possible to have ur ps2 trying to run a file on something that can only send so much data to it. Even a HardMOD[ meaning a chip is installed physicaly] its still hard to imagine someone trying to make that possible, but see if you have a Big ps2 then a hardrive is the only option, see the old ps2s were supposed to have a harddrive option but it endded up being a part of a game FFXI, so if you have a hardrive for the ps2 then you simply SoftMod it[ Software that mods the ps2 either threw the gamegenie or codebreaker and other programs, but the new ones dont have that option of a harddrive and if you have one you are out of luck using a harddrive as storage, but there is something called disc swapping.
see when you open ur ps2 tray theirs three or two buttons inside the slim ps2 that tell the ps2 when the dvd tray is open and thus it wont read a game till you close it.
but by tapping those key buttons down{ google how to do this,] you can burn a ps2 game and then with one legit ps2 game you first use the legit game and let it read then swap out the legit with any burned game and then one more swap and it allows you two play any burned game with just one legit game
http://www.youtube.com/watch?v=RimA3ZzIBEs heres for a phat ps2
http://www.youtube.com/watch?v=o7x5JItxJCE&feature=related more detail and also when you downlaod iso's u use a burnig tool to put it on a dvd, and yes you dont need the original game.
Oct 28, 2009 | Sony PlayStation 2 (PS2) Console
How do i transfer a saved file from usb to my memory card ?
you can transfer save files from flashdrives to memory cards by using Action Replay Max disc or similar similar devices
you need to buy it
Aug 22, 2009 | Sony PlayStation 2 (PS2) Console
I want cheats for Ridge racers5
I'm not sure if you're asking for cheat codes for use with Ridge Racer DS for the Nintendo DS, or Ridge Racer V for the Playstation 2 - Unfortunately, neither game has actual cheats built into them. You can, however, use a hex editor tool (also referred to as a Trainer, Gameshark, or Action Replay), which would allow you to cheat.
Intec Action Replay for the Nintendo DS: http://us.codejunkies.com/Products/NDS-Action-Replay---USA__EF000142.aspx
Action Replay codes for Ridge Racer DS for the Nintendo DS: http://us.codejunkies.com/search/codes/Ridge-Racer-DS_Nintendo-DS_17825879-17___.aspx
Intec Action Replay for the Playstation 2: http://us.codejunkies.com/Products/PS2-Action-Replay-MAX---USA__EF000306.aspx
Action Replay codes for Ridge Racer V for the Playstation 2: http://us.codejunkies.com/search/codes/Ridge-Racer-V_PlayStation2_1048770-1___.aspx
Mar 03, 2009 | Nintendo DS Console
My action replay max (ps2) won't load!!
flip ya ps2 upside down when loading its the only thing that works for me lol
Feb 27, 2009 | Datel Action Replay MAX for PlayStation 2
Ps2 action replay wont work on 60gb ps3
The Playstation (R) 3 has most likely been patched. I find it knocks back not only Action Replay but XPLODER also (The EU version of Gameshark) both for PS2 it is likely that SONY has blocked it out to stop consumers playing region locked dvd movies. So if you in UK you can only play Region 2 PAL dvd's, if you in the us, you can only play Region 1 NTSC dvds. If in AUS, you can only play Region 4 Dvd Disc....etc.... AR Max had a feature to bypass this problem, thus why sony has probably patched against it. As for a solution I am also searching for one, truth be told, I don't think there is one.
You should boot up your codes on your PS2, then the game.
Save your game.
Then copy your save game to your PS3.
Hope this helps.
Feb 06, 2009 | Sony Playstation 3 (PS3) Console
Mp3 player through playstation 2
I do recall some time ago that action replay max or something like that had some sort of media player in it. I'm not sure how limited it is though in it's functions. I wouldn't use this method anyway. What i would do If i were you is softmod your PS2 then load an app called SMS(simple media system) then you can play pretty much w/e you want. MP3's Avi's etc etc.
You got a lot of work ahead of you, if you want to do this the correct way. You can prolly get away with using action replay max or some other code breaker like disk that has a built in media player in it. You may get lucky and you may not. Reason I say this is, yes there are usb ports, no they don't read every single usb device on the market. SMS is more current and updated and supports way more USB thumb drives n such then action replay max ever will.
Step 1: Either mod chip or softmod your PS2. Softmods don't require a chip and i put up a forum post on the subject http://www.carpenoctem.ws/modules.php?name=Forums&file=viewtopic&t=13
A - Z with pretty lil pictures.
Step 2: Download SMS found .::HERE::. and add that to your memory card when you're making your saved game file (refer to my forum post to see what that means) Then launch your PS2 menu and load SMS and you'll be able to read your MP3's from a thumb drive that the firmware on your PS2 will support.
OR: roll the dice and spend money on a couple code breaker disks (with embedded media player) that may or may not work. The method I posted is guaranteed to work provided you own a FAT PS2 and not the SLIMLINE. If you own a slimline model then you have ZERO choice but to try the codebreaker like disks with embedded media player.
Hope that helps,
9x|
Nov 28, 2008 | Sony PlayStation 2 (PS2) Console
Usb port
I'm sorry to say but no one can solve this for you. Your only coarse of action is to go to the website that created the software ie. Action Replay Max or Code Breakers or Game Shark and check their flash drive compatibility lists. Reason I say this is, due to the limitations of certain versions of PS2's some flash drives will not work period. Where as some will only work with certain software. It's the same rule of thumb(pun intended :P) with hard drives. You're completely at the mercy of your PS2 and it's firmware. There are programs that are designed to help like USB advance and USB extreme that would make some drives work that would normally not, but you'll be wasting money if it doesn't work. I'ld start with the sites that make the code disks and see what they recommend you use, that woud be the best coarse of action.
Oct 10, 2008 | Sony PlayStation 2 (PS2) Console
Memory card to usb
im sorry but you cant put it on a usb. the usb ports are just for accesories like eyetoy or singstar, the memory cards are reserved for game files
Sep 13, 2008 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
9,055 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
