Question about Kodak EasyShare M1033 Digital Camera
Which cable to order?
What is the cable model number that is used in conjunction with the USB A/V connector. Want to hook up my computer to the back of the docking station. I have a choice of UBS U-8, USB U-5A or USB U--4 but don't know which one to order.Can you help? Thanks
  • 26 Answers
Sb5120
1.screw the cable line into the (F-connector)port in the back of the modem just like a tv does.2.then use the RJ-45 lan cable supplied with the modem,plug it into the RJ-45 port in the back of the modem.3.then plug the other end of the cable into the computers RJ-45 port.4.then power on the modem by pluging it in,and letting it boot and detect the internet signal and all lights are on and in working order.then start surfing.The only time you will need the install cd is if you need to use the usb hook up on the modem.
Jan 31, 2012 | Arris SURFboard SB5120 Modem
I USE TO HAVE A LAPTOP AND WAS ABLE TO DOWNLOAD MY PICTURES WITHOUT PROBLEMS. NOW I AM BACK USING A TABLE TOP COMPUTER, I HAVE THIS OTHER CABLE WITH A YELLOW & WHITE MALE IN-PUT AND THE OTHER END FITS...
Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer.
You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number..
319698101 .... CODE (USB 5P) CONNECTION
Thanks.
Jun 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
WHAT TYPE OF HARD DRIVE ADAPTER TO USB CABLE DO I NEED FOR THIS UNIT
This is an IDE drive - also known as PATA. To use it on a usb you will need a hard drive enclosure box. (For IDE not SATA) These are available from a number of places, online and computor stores. Will cost about $20 to 30
The box will have screws and connectors needed.
Mar 07, 2011 | IBM Travelstar DK23FA 60 GB EIDE Hard...
How do I connect the front usb wires to my fic c51g motherboard header?
How to Install Front USB by Connecting Front USB Ports to a Motherboard?In order to have front mounted USB you must have 3 things.
  1. A case with USB ports in the front of it.
  2. A motherboard that supports front USB (usually)
  3. Appropriate wiring between the USB port and the motherboard
A case can support front USB in two ways: via a pass thru connection, or via a port to header connection. The former, pass thru connection, is compatible with all motherboards that have USB ports. Pass thru front USB Pass thru front USB works by having the ports on the front of the case connect to either a standard USB cable, or a fairly small rounded cable. The cable goes from the front of the case to a special slot cover with either a hole (for the standard USB cable) or a special connector for the rounded cable. If the pass thru USB had a standard cable, then you would simply plug the standard cable into one of your back USB ports. If it had a rounded cable, then you have a secondary attachment with something that looks like an old style SCSI connector. The attachment plugs into both the slot cover, and the back USB ports. The draw back of pass thru front USB is that you lose the ports in the back.
Many 3rd party devices that add front USB to a system use the pass thru system. A good example is this now discontinued Front IO panel
directron_1721_2292726
Front USB via a Port to Header connection In order to hook up a Port to Header connection you have to make sure that the wires from your port will connect to your motherboard's header. To do this you need to know what header you have, and what type of connector you have on the wires. You'll find information on both below.
Almost all motherboards these days have a USB header. Due to size and cost restraints many motherboards only have 2 USB ports on their back panel, but often they can actually support more then 2 USB ports. They will typically support additional ports via the use of a USB header. A USB header is either a single or double row of header pins on the motherboard that can be used to add additional USB ports to a computer via the use of an appropriate set of header connectors, wires, and a USB port. Each pin on the header corresponds to a wire inside a USB cable. These pins must be clearly marked so that you can hook them up to the wiring correctly. There are 2 common layouts for a USB header.
Intel Standard USB header Layout: (used by over 90% of motherboards)
Gigabyte Style USB header Layout: (used most commonly on Gigabyte brand motherboards)
instusb2b
Now that we know the types of headers we have to take a moment to understand the USB wiring. Understanding the wires First off: All USB cables have 5 wires. 4 of these wires are actively used. Here's a reference from the official USB standard.
instusb3
On a front mounted USB port you'll have either the first 4 wires connected to properly colored wires (red for power, white/orange d-, green/yellow d+, black for ground) or all five wires attached to the port (same as the former, but one extra black wire). Now where it gets tricky is how to attach each of those wires to corresponding pins on the motherboard.
The wires are "tailed" (attached to a header connector) using any one of a number of different types of connectors. Below you'll find a list of the common ones.
Common USB case header connectors 4 joined pins + 1 extra ground.
usbheader
Compatibility: Compatible with both header arrangements because of the extra ground. May not work with some odd arrangements To hook up carefully match each pin. For the Intel hookup you'll have the extra ground wire not attached to anything. For the Gigabyte hookup you'll have the extra ground hooked to ground pin on the motherboard, and the standard ground jumper will be over the missing pin on the header.
All pins separated
instusb6
Compatibility: Compatible with every header. If all the pins are separated the only real issue is lining up the pins with the appropriate places on your header. It should be compatible with all headers. Just make sure you read the writing on each individual connector. Please check the troubleshooting info at the end of the article for important information on this configuration
Power and Ground separate, d-, d+ joined Lian-Li style
Compatibility: Compatible with all common headers. This sort of arrangement is common to almost all Lian-Li cases. Make sure that you get the wires connected to your header in the proper order. If you find that the port does not function the most common cause is accidental reverse of the d-,d+. Try switching it.
All pins joined Intel style easy connector
usbinst4
making the Connection Once you know what type of header you have, and what type of connector you have on the wiring, you need to connect the two of them. In order to do this, you must first figure out what pin goes with what part of the connector. To do this, you should first consult your motherboard manual. Below you'll find an excerpt from a fairly recent motherboard manual for the Asus A7M266 motherboard. It's typical of a motherboard manual for a board using the Intel standard USB header.
instusb5
The first thing you'll probably notice is that the wiring from your case and the names of the pins might not quite match up name wise. This is a common problem. Motherboard makers and case makers really haven't decided on what to call each pin. Here's a rough list of names.
Power may be called: P, VCC, USB Power, Power, and PUSB. On wiring it's always red. Ground may be called: G, GND, Ground, and GUSB. D- may be called: USB-, USBP-, D-, or just -. D+ may be called: USB+, USBP+, D+, or just +.
To complicate things a bit more you'll probably notice that there's a number before each one. Take a look at the picture above from the USB hookup diagram for the A7M266.
You'll see that Asus decided to number the middle pins. On the first row (starting with pin 1, and marked with a 1) you'll find that they list D- as USBP2-, and D+ as USBP2+. The number 2 tells you a few things. First off: It's the 3rd USB port on the motherboard (they started numbering at 0), second it tells you that that D- and D+ must be used for the same port. Case manufacturers are just as likely to number their ports differently.
Take a look once again at the 4-pin joined picture: usbheader
Notice that you're D-'s have either a 1 or a 2 on them. These also tell you that they are part of the same USB port. (Remember, 1 port has 4 required wires). The numbering on the connector and the numbering on the header doesn't have to match.
To connect everything grab the following connectors: a same number D pair, (D-, D+), 1 power, and one ground. If your power and ground are numbered make sure all 4 are the same number.
Tip: Most cases that use all separated pins will bundle these together for you to make it easier.
Now, take your Power, D-, D+, and Ground and line the connector up with the appropriate 4 header pins on your motherboard. The header pins will be in a row under the Intel style, and in the Gigabyte style it will either be a row of 1 pin, a gap, and then 3 pins, or 3 pins, a gap, and then 1 pin. Press the connector down over the header pin and make sure it's firmly attached. Once you have done this go back and grab another set of connector wires (Power, D-, D+, Ground), and hook up your second front USB port. If your case has more then 2 front USB ports, and your motherboard has more then one front USB headers, then repeat the above as necessary.
Example: If you were hooking up the front USB on a A7M266, on a case with the pictured 4-pin joined connector type then: VCC lines up with USB Power, USBP2- lines up with USB1-, USBP2+ lines up with USB1+, and GND lines up with GND. For port 2, VCC lines up with USB Power, USBP3- lines up with USB2-, USBP3+ lines up with USB2+, and GND lines up with GND.
May 21, 2010 | Computers & Internet
Files & settings Wizard XP Pro
1) Are you referring to the IBM ThinkCentre S50?
(S may look like an 8)
Also need the Type. On the back of your ThinkCentre is this information.
Example: TYPE 8125-E1U
(The S/N after it stands for Serial Number. Do not give this number out, except to authorized personnel)
(I can give you the direct link to Lenovo Support for the Ethernet drivers, with this information.
IF, upon installing the Ethernet drivers does not cure the problem,
look to see if there is an open, {Available}, PCI slot for an Ethernet card.
With the 'Pizza Box' style of computer case there may not be, nor may there be room inside.
However they do make low profile Ethernet cards. {Ethernet Adapter Card)
Or you can find it here,
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=TCTR-MATRIX
It will go in an available PCI slot, or PCI-Express x1 slot.
2) The Model Name, and Model Number is on the bottom of a laptop. Usually in a white Service Tag of some sort, but older models may just have it etched into the plastic.
Usually close to the Windows Product Key, (Holographic sticker)
3) Use a USB to USB Crossover Cable.
Example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3272684&sku=C184-39977
A USB to USB Crossover cable, isn't simply two USB A male connectors on the ends of a cable.
There is a bridge in the middle of the cable.
It crosses over the wires.
(Easy explanation. In essence it crosses over the wires. In actuality, it crosses over terminals in the USB connector end.
This shows the pinout of a USB cable connector,
http://pinouts.ru/Slots/USB_pinout.shtml
The style used for your desktop, or laptop will be a USB A style.
There are four pins in the connector.
Pin 1 is 5 Volt DC
Pin 4 is a Ground, or Negative connection)
If you have a cable with the ends in the same direction, you will BURN out the USB ports.
The crossover cable reverses these connections. (Pins)
I await the exact Model Number of your IBM ThinkCentre, and the Type.
Jan 04, 2010 | Computers & Internet
Have system for voip. Only can't hook up the
Try getting a router that has one in/4 out between modem n voip. Your voip unit should have an RJ45 connector to connect to router, not your computer. The USB connector might be to connect the voip to a different type of router, and will not be used. The 2 phone connectors are for two different phone lines that your voip provider can provide you with.
Sep 20, 2009 | Toshiba DOCSIS Cable PCX2600 (DAZ8823A-R)...
I am trying to find that what type of cable I
depending on what connection you have on your computer. You can use usb to usb or dv to dv. If you use usb to usb it's pretty straightforward but if you go dv to dv just make sure which dv connector you have on your computer 4 or 6 pin. If you don't have a manual for your jvc , go to their website and download one. All of the info will be in there, usually towards the back of the manual. My suggestion would be if you have a dv connector on your pc you should use that setup because it is faster than usb. But if you don't have a dv connector, usb to usb is fine. Have fun.
Jun 29, 2009 | JVC GR-D270US Mini DV Digital Camcorder
Power problem
According to the owners manual: http://support.dell.com/support/edocs/systems/PRN942/en/om/942_om_en.pdf The power connector is next to the USB connector in the back of the printer. You use the AC adaptor to hook up the printer to a wall outlet to give it power and then the USB Cable is hooked up to the computer so you can install the printer software to the computer so it recognizes the printer.
Jun 04, 2009 | Dell 942 All-In-One InkJet Printer
Firewire vs USB
If there is not a USB connector port on your model, then you could buy a FIREWIRE to USB adapter. Price is not cheap!
It may be cheaper to install a FIREWIRE PC CARD on your PC.
Hope this helps!
Jan 01, 2008 | Panasonic NV-DS60 Mini DV Digital...
Kodak EasyShare M1033 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
