Question about Dell 3100cn Laser Printer
Dell 3100cn Shows error message: BTR Cover is open (077-302) Where is BTR cover? I could not find please help- thanks
    Scholar:
  • 136 Answers
The BTR cover is also called " Bias Transfer Roller " cover it should be that roller that seen when open the front cover most likely the Bias transfer roller door sensor in NOT detecting the dorr closed. make sure the tab isn't broken this will produce this error if it is.
Posted on Jul 24, 2009
This message board posting may address your question: http://en.community.dell.com/support-forums/peripherals/f/3528/t/19291697.aspx
Jun 02, 2013 | Dell 3100cn Laser Printer
Paper cover error message
check the back cover is closed properly or check the cables are well connected to therear cover
Nov 20, 2011 | Dell 3100cn Laser Printer
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Error message, ''close BTR cover'' for Dell 3100cn
The BTR cover is covered the fuser. If you open the rear door, it is located at the upper part, behind the metallic rod. The problem is the cover is installed unproperly: Its metal piece is not touched against the metal piece of the machine, so the machine does not "smell" the BTR cover.
Nov 18, 2008 | Dell 3100cn Laser Printer
Dell CLJ 5110
Pop the lens cover off of the transfer roller, clean all the toner debris out of there and replace the lens, put clear tabe on it, and you are good as new!
Oct 09, 2008 | Dell 5110cn Laser Printer
Close reg cover
After researching the error online, I solved my problem by simply pushing the back cover of the unit closed; I didn't even know it had come open after I removed my jam.
Hope this helps!
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section20.html#638412
Jul 18, 2008 | Dell 3100cn Laser Printer
Thw reg cover can not closed.
At the bottom of Opened Reg Cover, it has a flexible horizontal panel, I make it upright use any ways, the Reg Cover closed easily.
Mar 31, 2008 | Dell 3100cn Laser Printer
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Toner install error
they could be a knows fulty black toners for these do u have all latest software is ther firmware update for the machine avb tonner droped in very well instaled lid latch broke
Jan 29, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Jul 28, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
662 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
