Grinders Logo
Rhickz Ramos Posted on Mar 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is motor starting capacitor of GB800 Bench grinder
Pieter Vleeshouwers
Level 3:
  • Bench Master 2,029 Answers
  • Posted on Apr 19, 2017
Pieter Vleeshouwers
Bench Master
Level 3:
Answers
2029
Questions
0
Helped
4112549
Points
7389
Hard to find the data The tool is having an centrifugal switch to an breakercontact on the armature on the startup-winding where the capacitor is on , so it should be oft a high capacitance try it to start with 20 mf is maybe high enough to start. you can possible go to less with the capacitance . size compare of the capacity range is difficult because the last years the size differs much and are less
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on Aug 27, 2008
SOURCE: Bench Grinders Safety issues
Goggles or safety glasses need to be worn to protect the operator's eyes from the sparks and metal filings that result. Depending on the workpiece and time of exposure, hearing protection may also be required, the dust produced is also potentially hazardous. The toolrest (or workrest) should be mounted slightly below the center of the grinding wheel with less than 3 mm clearance from the wheel. This prevents the work from jamming between the toolrest and the wheel. Grinding wheels designed for steel should not be used for grinding softer metals, like aluminium. The soft metal gets lodged in the pores of the wheel and expand with the heat of grinding. This can dislodge pieces of the grinding wheel. Wire brushes require particular attention for the safety of the operator and bystanders as the metal wires may become dangerous projectiles as they could bind with the object being brushed and so throw it away with great energy. The machine needs to be securely mounted to a pillar or a bench to be used safely and effectively, often with an emergency stop switch or pedal fitted close by the machine, for use in emergencies.
Anonymous
  • 6 Answers
  • Posted on Jan 26, 2009
SOURCE: Given a bench grinder which did not work. How to test/fix?
I cleaned all the wiring connectors etc and used a 4-way extension cord with an i/o switch and thermal/arc breaker surge protector thingy. I had a piece of thick cable with a molded three prong plug which I had removed from a dead paper shredder (I think??) and connected the ground to the case (previously not connected) the black to the black and white to the white. I taped the connections and plugged the test cable into the extension thingy with its switch off and plugged it into the wall outlet. Then, with the grinder switch on, I gingerly switched on the extension thingy and the grinder (sans all moving parts) ie just the motor case and spindle (held securely in the B&D workmate) and viola(!) it worked fine and built up to very fast. I switched off the grinder switch and the motor slowed, taking an age to come to rest.
Then, I fitted a grinding wheel on the left hand thread end, tightened everything and retested, using the grinder switch to start it and it spun really fast.
Soooo, I guess the secure ground is an essential feature of a capacitor induction motor. I checked some old furnace motors that were "maturing" in the basement and they had no capacitor but only 2 wires...
I am now trying to remember which parts came off last and put it all back together. I plan to test it each time I put a part back...just in case. I hate it when you fix something on the bench and when rebuilt, it won't work...don't ask about the electric starter on the snowblower..not a happy puppy!
Please, pretty please and then some, do tell me if my "fix" is wrong and I could risk all kinds of nastiness.
Thanks,
Jenni.
marionbagget
  • 718 Answers
  • Posted on Mar 28, 2009
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
Fred Yearian
  • 5603 Answers
  • Posted on Nov 16, 2009
SOURCE: bench grinder, 110/220?? wired up properly
LIKELY the capacitor which is usually in the base is bad.
The capacitor shifts the phase angle in one of the two windings which creates a pseudo rotating field to start rotation.
Anonymous
  • 172 Answers
  • Posted on Jan 13, 2010
SOURCE: Need part numbers to replace eyeshields on Dayton bench grinder
Your grinder is listed on page 3085 of the Grainger catalogue. The part number for the eyeshield is 00281.00 and the number for the lower eyeshield bracket is 00280.00. The right hand upper eyeshield bracket is number 25188.00 and the upper left hand bracket number is 25177.00. All of this can be ordered through Grainger at 1-800-323-0620. Marvin T.
Testimonial: "This was very helpful. I have ordered parts from Grainger. Thank You."
Will not start
The centrifugal switch inside has gotten dirty, or else the start capacitor is disconnected or faulty. It's about time to open that grinder up and examine the centrifugal switch. If it's working OK, then examine the capacitor connections. If they look OK, replace the capacitor.
Apr 25, 2014 • Grinders
1helpful
2answers
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
1helpful
I have a ludell (machine tool) bench grinder. The problem is that the grinder disc will not turn. The motor hums but won't turn. I took the disc off and turned the shaft by hand with the powder on and it...
Ah, the start winding is not operating. When you turn the motor by hand. When the motor speeds up, do you hear a click sound? This is the start winding switch working. There might be a capacitor that is wired in with this switch that is used to start the grinder. If this capacitor is fried, the motor will not start. If the switch is shot, also the motor will not start. There could also be a wire or connector in this part of the motor that is not connected, or fried and not making contact. These are a few things to look for.
Jan 30, 2011 • Grinders
1helpful
My 6 inch Cummins bench grinder stopped working. When you turn on the switch it only has a quiet hum. Is it the capacitor?
Try wrapping a thin cord around the shaft many times to allow the shaft to be spun in the normal running direction when pulled. Pull sharply on the cord and turn the motor on--if the starting capacitor is bad, the motor should continue to run until shut off. If there is no capacitor, then the motor uses a start winding and a centrifugal switch to start. The switch is supposed to open when the motor comes up to speed. If you used to hear a loud 'click' when the motor was shut off and slowing down, then you likely have the start winding and switch. If the contacts on the switch become burned and not make contact, then it will display the symptoms you mention. You will need to access one or the other end covers to reach the switch. Hope this helps!
2answers
I have a Taiwan made 1/2 hp bench grinder that wont run only hums and now it wont even run if I spin it by hand and no capacitor. Is it junk now.
Hi there, with out seeing it I`d say your brushes are gone and ceasing. I hope this solves your problem.
May 18, 2010 • Grinders
It hums but won't turn. are there brushes? what is the black canister hooked to wiring going to motor? aloha, chip
Hi Chip , have you tried !!carefully!! turning the grinding wheels whilst the grinder is powered up and humming and does this start the machine , if it does your motor start capacitor ( a cylinder/tube with 2 wires or connectors on it ) will be deffective or the leads might have became detached from it , a replacement capacitor is quite cheap but you must replace it with the exact one ( a motor start/run capacitor of the correct Mfd or uF rating typically 30 uF/Mfd and at the correct voltage 110/220V )
if this dosent fix your problem most likely your motor start windings in the motor field coils are burnt out and the grinder is uneconomical to repair .
hope this helps .
3helpful
Bench grinder, 110/220?? wired up properly according to diagram on grinder, just turns on as soon as it's plugged in but it just humms, it does not spin the grinding wheel.it is a monster w/ a 3/4 hp...
Nov 07, 2009 • Saws
1helpful
Bench grinder buzzes
The capacitor has failed. Take it out and go to a motor shop for a new one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
1helpful
Grinder starts and stops on startup
if this is a cap start motor and not a centrifugal start run motor then bad cap is good place to start
Top Bench Grinders Experts
Oliver Street
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Bench Grinder Expert? Answer questions, earn points and help others
