Question about Kitchen Ranges
Hotpoint Gas Range. We changed the jets from Natural to Butane. Now when we try to light a burner it flames up and then dies down to a flame like a pilot. There is no pressure.
    President:
  • 1,714 Answers
The jets that you have installed have to be correct for the altitude that you live. If the jet is too small, too little gas, no flame. Low altitude (sea level to 2500) means a larger jet for more fuel because there is more air. High altitude is less air and less fuel (smaller jet)
Posted on Jul 23, 2009
    President:
  • 1,136 Answers
Hi, Did you change the setting/cap on the regulator? The orfices in the oven need adjusted as well.
Please let me know if I can assist you further in this matter.
Thanks
Vic
  • Victor
    Victor Jul 23, 2009
    Thanks
    Vic
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Orange flame
A orange flame means that not enough air is mixing with the gas to produce a nice clean burning blue flame. Try cleaning out any deposits of grease or anything else that could be blocking the air pathway to the flame.
Mar 23, 2014 | Frymaster Dean FPEL4 Deep Fryer
Gas bbq
flame running back is an indication of insufficient gas pressure or flow. check and adjust the regulator and ensure that there is no blockage in the jets.
May 14, 2013 | Grilling
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
Can't get even flame on burners
Natural gas and Propane operate at different pressures known as WATER COLUMN INCHES and require different jets to work properly.
If you have changed the jets ( installed in the correct direction) and are using a new LP regulator You should be good to go. If you are using the old Nat Gas regulator it just ain't a goin a work
Feb 15, 2010 | Grilling
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Flames in oven are WAY too high! Having trouble lowering them.
Hi! melisrus
If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint.
www.hotpoint.com
Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top.
InMrFixIt
Nov 18, 2008 | Kitchen Ranges
Did you change the orifice in the regulator? The orifice opening for LP is a different diameter than the opening for Natural Gas. If you've already attempted changing the settings from Natural to LP, you may want to double check the orifice under the regulator cap, or...you may have a regulator problem. You will need to turn the gas off prior to attempting this. The regulator will be located in the back of the oven somewhere near where the gas line connects to the stove. There is a gas orifice that needs to be turned over to change gas settings. "LP" should be present if it is set correctly. Let me know if this helps.
Jul 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
103 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
