Question about Shortcut Computers & Internet
I want to create a shortcut on Viera remote for Netflix
Is there a way of assigning a button to directly access Netflix instead of navigating through several screens through Viera connect?
SOURCE: compaq keyboard
You probably need to load the Compaq utility that assigns and activates the keys. Go to http://h18000.www1.hp.com/cpq_support.html
enter the model number of your compaq computer, and search the available downloads for the utility.
Posted on Nov 27, 2007
SOURCE: The shortcut Ctrl+ right arrow, Ctrl+shift+right
Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience.
Posted on Apr 15, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Lost internet access WiFi and direct
Go to control panel > Device Manager > scroll down to the network devices and click on the plus sign. Highlight the wireless device. Right click on it and choose uninstall. click ok and reboot the system. When windows reloads, it will recognice the new device and want to load the drivers for it. It may ask you if it can search windows update for a fresh driver, allow it to continue. The drivers will load and the correct settings applied. All should be as it should.
Posted on Sep 21, 2009
g33k4u
  • 485 Answers
SOURCE: how do you connect a
You need some type of device that comes with the NetFlix program such as an XBOX 360 or PlayStation.
If this helps please thumbs up my solution!
Posted on May 04, 2011
SOURCE: how can i delete a
Disregard the other solutions. Open your Netflix App and do the following:
Hit the arrow keys on your remote.
Up, up, down, down, left, right, left, right, up, up, up, up.
Posted on Jan 20, 2013
Tip
Create a Shortcut or Hotkey to Eject the CD/DVD Drive
Create a Shortcut to Eject the CD/DVD Drive
Right-click on the desktop or elsewhere and choose New \ Shortcut.
In the location box, put the full path to the nircmd.exe file that you downloaded, and append the "cdrom open" command to the end of it, adjusting the drive letter to match your disc drive:
"C:\path\to\nircmd.exe" cdrom open D:
Note the location of the quotes.. if you are using a path with spaces in it, you need to make sure the quotes are only around the path to the executable, and the arguments should be placed after the quote.
Give the shortcut a meaningful name, like Eject CD or something like that, and you'll have a new icon (read below on how to use the cd-rom icon as shown)
Create a Shortcut to Close the CD/DVD Drive
You can follow the same exact instructions as above, but instead of "cdrom open" just substitute "cdrom close".
Assign a Hotkey to the Shortcut
Now that we have a shortcut, we can assign a hotkey to the shortcut by right-clicking on the icon and choosing Properties. On the Shortcut tab you'll see a place to assign the Shortcut key:
on Apr 29, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Volume control
Yes,you can create a Master Volume Shortcut and also assign a Shortcut Key.
Right click on a empty area on desktop, and click on New and Shortcut.
Paste the following in to the location of the item area:-
%windir%\System32\SndVol.exe -f 49825268
Click Next button and give a name to the Shortcut and click Finish.
Now You right click on it and select Properties.
Click Shortcut tab.
Assign your desired shortcut key like F8 or F9 in the Shortcut Key area.
Click OK/Apply
Is There Keyboard Shortcut For Volume Control
Mar 13, 2015 | Computers & Internet
How do I down load I-con for Netflix on my laptop
I'm confused as to what's wrong.
You went to Netflix.com and downloaded / installed but no icon showed up? Or your watching directly from Netflix? Do you have a shortcut with no icon on your desktop? Or you have no shortcut at all?
What OS are you using?
Below is for Windows XP / 7
To fix you have short cut with no icon you can follow steps below or download it again and re-install
Open Internet Explorer or any web browser and go to http://findicons.com/search/netflix. Click the image you wish to use and download the ico version.
Right click the shortcut to Netflix on your desktop and click change icon. Browse to the ico file you saved.
There are other icon sites out there. This is the first one I found that SEEMED safe to use, but I do not own the site.
To fix your watching directly from Netflix with no shortcut or icon.
Right click on your desktop and click create shortcut
copy and past this https://www.netflix.com/Login?locale=en-US
name it Netflix.
If I got your needs all wrong please explain more.
Feb 14, 2015 | Microsoft Windows XP Professional for PC
How do i download netflix for computer
You can always access it through Netflix.com
Make sure you have installed Microsoft Silverlight since its required to stream content from Netflix.
You can always save the site to your favorites and create a shortcut to your desktop for ease of access.
Oct 18, 2014 | Dell Inspiron Computers & Internet
I was assigning new products to my m202 keyboard however I accidentally assigned a product to the PLU list key. Is there any way to remedy this
Create a shortcut
Open the folder or directory that contains the program you wish to create a shortcut for.
Right-click on the program and click Create Shortcut.
This will create a shortcut named "Shortcut to <your program> in the directory you are in. If you wish to rename this shortcut, right-click the file and click rename.
Once the above steps have been completed, you can copy or cut this shortcut and paste it anywhere to execute this program.
Assign shortcut key to that Windows shortcut
Once the shortcut has been created to assign a shortcut key to that Windows shortcut follow the below steps.
Right-click the shortcut and click Properties.
Click the Shortcut tab.
Click in the Shortcut key box and press a letter. For example, if you press "p" the shortcut key will automatically be made Ctrl + Alt + P. Which means if saved when pressing Ctrland Alt and "P" all at the same time will run that shortcut.
hope this helps
Jun 07, 2012 | Computers & Internet
How do you connect a panasonic viera tv to netflix?
May 04, 2011 | Televison & Video
How can i delete a netflix account from my panasonic viera tv without accessing the netflix account?
Jan 11, 2011 | Panasonic Viera TH-42PX80U Plasma TV
How do i add a link or button to my web-side
you can create a short cut on your desktop and access any time you need..
When you have a website that you visit often, its better to create a shortcut on desktop ragher than always searching for it Here is the step by step instruction on how to create website shortcut on desktop 1.Right click on empty space of the desktop 2.Navigate to NEW-> Shortcut
3.A shortcut wizard will open up You have to enter the URL ( website adress) of the website.You can type it manually or you can copy and paste it from address bar.
After entering the URL, Click Next, Enter the name of the shortcut.
Click Finish
Now you can see the short cut on the desktop. once you double click on it, it will take you to the website.
Jun 13, 2010 | Computers & Internet
I need to creat ip from my router for my friend that will have starting time and ending time.
Navigate in your browser to the control panel of your router ( typically http://192.168.1.1 ). Leave user blank and enter your password. Then navigate to tab Access Restrictions, create a policy with the times you want, click the Edit List of PCs button to assign policy to your friends computer, then click Save Settings button.
Jan 22, 2009 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
26 people viewed this question
Top Shortcut Computers & Internet Experts
David Payne
David Payne
Are you a Shortcut Computer and Internet Expert? Answer questions, earn points and help others
